bbfl333
Optimized PDF and Reduced Size not working
Apr 22, 2012 9:04 AM
Tags: #acrobat #size #pdf #pro #optimize #reducing
Hello,
I have a problem with Adobe X Pro. When I want to optimize or reduce the size of a pdf document, in the most cases it doesn't reduce the document but just save the same document with no changes but I make significant changes putting 72 ppi for all imiges! I get this message at the bottom almost all the time "Removing Items" and after that "Saving File" and nothing after that. The size is the same! WHY IS THAT?
    Apr 23, 2012 7:03 AM   in reply to bbfl333
    Perhaps your images are already 72 ppi. Have you tried running the Audit space usage command (in the top right corner of the PDF Optimizer menu) to see what is taking up the most space in your file?
    Apr 24, 2012 11:26 AM   in reply to bbfl333
    The Optimizer only works on images if there is a reduction is size, which may be why it appears to work sometimes and not others. If you want to double check any particular image, you can open the Output Preview dialog under the Print Production panel and select Object Inspector from the Preview dropdown. Then you just click on the the image to find out information about it.
  • lilia@
    Jan 31, 2012
    Apr 29, 2012 11:23 AM   in reply to bbfl333
    by saving the file... you need to do a "save as" not "save"... save as rewrites the file.
    oh and you might want to check the audit space usage to see which components are taking up the most bytes.
