mdnavaz
How can I control a button from one swf file to another swf file?
Apr 22, 2012 1:18 PM
I have a main.swf file. From that file I am accessing the external.swf file which is an external file.
Now, how can I write code on my main.swf file for the button which is on my external.swf file?
Activities.MainPanel.close_btn.addEventListener(MouseEvent.CLICK, btnClickClose);
Activities.MainPanel.close_btn (This buttons is actually on external.swf file, but I want to write code on main.swf file to execute it on external.swf) how can I control one swf button on other swf file?
Thanks.
    Apr 22, 2012 3:38 PM   in reply to mdnavaz
    Is external.swf loaded into main.swf? If that's so then external.swf is a child of main.swf. Look in the online help for information on communicating between parent and child objects.
    Apr 22, 2012 9:53 PM   in reply to mdnavaz
    Depending on your setup you have a few options.
    1. local connection, not the best but works
    2. direct control - as Rob said, access the object based on its position in the display list of the Loader content (the Loader content is your external.swf)
    3. class control - if your button is a custom class (should be, if not then make it so), then create a new instance of the class
    4. static control - create a static reference to the element and call the reference
    Apr 23, 2012 5:22 AM   in reply to mdnavaz
    Here's some example code that you should be able to adapt to your needs.
    // create a new loader object instance...
    var loader:Loader = new Loader();
    // make the download request...
    var request:URLRequest = new URLRequest("external.swf");
    // add a complete event listener to the loader
    loader.contentLoaderInfo.addEventListener(Event.COMPLETE, completeHandler);
    // start the actual loading process...
    loader.load(request);
    // create a new empty movieClip instance, you will put the loaded movie into this movieClip once its loaded
    var externalMovie:MovieClip;
    // this function is called when the download has finished and the file is ready to use...
    function completeHandler(event:Event):void {
       // set the contents of the loaded movie to the new empty movieClip...
               externalMovie = MovieClip(event.target.content);
       // add this new movie to the display list...
       addChild(externalMovie);
    Now you can refer to the loaded movie with the instance name "externalMovie". So if, for instance, you want to address a button in the loaded movie, you could write something like this on the main timeline:
    externalMovie.addEventListener(MouseEvent.CLICK, btnClickClose);
    function btnClickClose(event:MouseEvent):void {
