Searching GREP expression through scripts
Apr 23, 2012 4:05 AM
<note id=”law-(\d+)-note-(\d+)” type=”footnote”>
        Using the above syntax in the code written below, I am trying to search all the note id's from footnotes, only through scripting. But every time I run it I am getting an error "d is undefined" . Please anyone tell me how to do it.
code
var myDocument = app.activeDocument;
var myStory = app.documents.item(0);
app.findGrepPreferences = null;
app.changeGrepPreferences = null;
app.findChangeGrepOptions.includeFootnotes = true;
app.findChangeGrepOptions.includeHiddenLayers = true;
app.findChangeGrepOptions.includeLockedLayersForFind = true;
app.findChangeGrepOptions.includeLockedStoriesForFind=true
app.findChangeTextOptions.wholeWord = false;
var test2="<note id=\"law-"+"\\"+d+"-note-"+"\\"+d+"\""+" "+"type=\"footnote\">"
app.findGrepPreferences.findWhat =test2
app.select(app.activeDocument.textFrames.item(0).findGrep())
  • John Hawkinson
    Jun 25, 2009
    Apr 23, 2012 4:31 AM   in reply to Ranjan_123_singh
    I don't see how this could possibly work.
    Can you please post a screenshot of what you are searching for in InDesign, with Show HIdden Characters enabled?
    But it looks like you're searching for an XML representation, I don't see how that could ever work.
    This produces an error because it references the variable "d".
    I don't know what you're trying to do, but you are concatenting several strings to form test2. Let's write it like this:
         d+
         "-note-"+
         d+
    Again, I don't know what you intend, but that clearly references the contents of a variable called 'd', which does not exist.
    I suppose you want something like "\\d+" instead of "\\"+d but that's just not going to work either, for other reasons....
    I would probably write the regexp as
    var test2=/<note id=”law-(\d+)-note-(\d+)” type=”footnote”>/.source;
    which should (hopefully) solve your quoting problems...but it still won't work.
  • John Hawkinson
    Jun 25, 2009
    Apr 23, 2012 10:00 PM   in reply to Ranjan_123_singh
    Well, if that's the case, my example ought to work.
    THough...I seem to have ended up with curly-quotes somehow. Did you make them straight-quotes? That's probably necessary. i.e.
    var test2=/<note id="law-(\d+)-note-(\d+)" type=”footnote”>/.source;
    not
    anyhow, in my first reply, I asked:
    It would be good for you to do that.
    If the above test2 expression does not work, you should try simplifying it until it does work.
    Start with
    var test2=/<note id="law->/.source;
    and make sure that works, and then continue adding in pieces.
    It might be helpful to print it out with
    $.writeln(test2);
    so you understand what's going on.
  • John Hawkinson
    Jun 25, 2009
    Apr 24, 2012 6:07 AM   in reply to Ranjan_123_singh
    Ranjan, I can't help you if you do not answer my questions.
    Please reread my responses and answer the questions I asked you, especially the ones in boldface.
    Check, also, the suggested $.writeln() output, and simplifying the regular expression and cutting it down.
    Again: Help us, help you. Thank you.
