Saving PDFs
Apr 23, 2012 7:26 AM
Branched to a new discussion.
    Apr 23, 2012 7:26 AM   in reply to Community Help
    It's pretty annoying that I'm now given a half dozen options on which format to "save" as when I save just as a simple PDF file 99.999999999999999999999999% of the time.  Can we eliminate that second "save as" menu?
    Ed
  • George Johnson
    Aug 11, 2002
    Apr 23, 2012 10:21 AM   in reply to Ed at DCMAasdfasdf
    Consider using the keyboard shortcuts: Ctrl/Cmd+S for Save and Shift+Ctrl/Cmd+S for Save As
    May 16, 2012 6:57 AM   in reply to Community Help
    Option to Save as Reduced Size PDF in Acrobat 10 Pro greyed out. Security set to Off, so no restrictions. Any thoughts..?
    May 16, 2012 9:51 AM   in reply to Ed at DCMAasdfasdf
    They moved most of the various save options to the save as for ease of use. Sorry that you find it annoying. The Save As to a PDF also does additional processing that the Save does not. The Save does not remove unneeded information and often allows the PDF to bloat. I have seen folks complain about it growing by a factor of 2 or more with just a simple edit. The Save As usually resolves this issue. This process was not new to Acrobat, but was something that WORD did for a long time also. Don't know who started the trend.
    Aug 10, 2012 10:32 AM   in reply to Community Help
    I am trying to save as a reduced size pdf, and adobe is telling me I don't have authority.  I'm then instructed to go to security settings, which tell me I have authority.  Can anyone help with this?
    Aug 10, 2012 8:06 PM   in reply to store5405
    Is the PDF set as a PDF/A file. If so, that may be the issue. I think you can remove the PDF/A category with preflight and try again. (work on a copy)
    Oct 5, 2012 4:43 AM   in reply to Community Help
    Hi
    I open a saved PDF - create text recognition - and want to save it again (CTRL S) with the same name, howver, I get the info that "this file is set to read-only. Try again with a different name". It's a normal scanned document and no special restrictions /settings has been made.
    Who can help me?
    Regards Bente
    Oct 5, 2012 7:10 AM   in reply to Bente Yvonne
    Sometimes files like this are automatically set to readonly. Right click on the file in Windows Explorer and check the readonly status.
