SnpCreateTabbedPaletteScriptUI not working. Help me.
Apr 23, 2012 10:00 AM
Tags: #tabbed #snpcreatetabbedpalettescriptui #pallete
I want to have a new pallete window on my bridge and the SnpCreateTabbedPaletteScriptUI script from SDK samples helped.
But only when I try it from running from Extendedscript Toolkit CS5.
When I put it on running from Bridge startup scripts, it doesn't work anymore.
I guess it has to do with the windows7 itself??? But I don't know.
I'm running as administrator.
The SnpCreateTabbedPaletteScriptUI code:
// ADOBE SYSTEMS INCORPORATED
// Copyright 2008 Adobe Systems Incorporated
// All Rights Reserved
// NOTICE:  Adobe permits you to use, modify, and distribute this file in accordance with the
// terms of the Adobe license agreement accompanying it.  If you have received this file from a
// source other than Adobe, then your use, modification, or distribution of it requires the prior
// written permission of Adobe.
 @fileoverview Shows how to create a TabbedPalette in Bridge with ScriptUI components.
 @class Shows how to create a TabbedPalette in Bridge with ScriptUI components.
 <h4>Usage</h4>
<ol>
<li>    Run the snippet in the ExtendScript Toolkit (see Readme.txt), with Bridge CS5 as the target.
<li>You should find that a tabbed palette has been added to the Bridge browser window.
</ol>
 <h4>Description</h4>
 <p>Adds a script-defined tabbed palette to the Bridge browser window.
 <p>The palette is of the "script" type, and contains ScriptUI components,
 text fields and buttons. The buttons have event handlers that
 change the values in the text fields.
 <p>The new palette appears in the default upper-left position in the browser. It can be
  dragged to other positions. <br />
 @see SnpCreateWebTabbedPalette
 @constructor Constructor.
function SnpCreateTabbedPaletteScriptUI()
     The context in which this snippet can run.
     @type String
    this.requiredContext = "\tExecute against Bridge main engine.\nBridge must not be running";
    $.level = 1; // Debugging level
    this.paletteRefs = null;
 Functional part of this snippet.
 Creates the TabbedPalette object, defining the content with
 ScriptUI components, and adds the palette to all open Bridge browser windows.
    @return True if the snippet ran as expected, false otherwise.
    @type Boolean
SnpCreateTabbedPaletteScriptUI.prototype.run = function()
    var retval = true;
    if(!this.canRun())
        retval = false;
        return retval;
    this.paletteRefs = new Array();
    var wrapper = this;
    // Create and add the TabbedPalette object and its contents.
    function addScriptPalette(doc)
        // Create the TabbedPalette object, of type "script"
        var scriptPalette = new TabbedPalette( doc, "SnpCreateTabbedPaletteScriptUI", "SnpSUIPalette", "script" );
        wrapper.paletteRefs.push(scriptPalette);
        // Create a ScriptUI panel to be displayed as the tab contents.
        var tbPanel = scriptPalette.content.add('panel', [25,15,255,130], 'The Panel');
        // Add the UI components to the ScriptUI panel
        tbPanel.txtFieldLbl = tbPanel.add('statictext', [15,15,105,35], 'Times Clicked:');
        tbPanel.txtField = tbPanel.add('edittext', [115,15,215,35], '0');
        tbPanel.addBtn = tbPanel.add('button', [15,65,105,85], 'Add');
        tbPanel.subBtn = tbPanel.add('button', [120, 65, 210, 85], "Sub");
        // Define event listeners that implement behavior for the UI components
        tbPanel.addBtn.onClick = function()
            var txt = tbPanel.txtField;
            txt.text = parseInt(txt.text) + 1;
        tbPanel.subBtn.onClick = function()
            txt.text = parseInt(txt.text) - 1;
    // Add the palette to all open Bridge browser windows
    for(var i = 0;i < app.documents.length;i++)
        addScriptPalette(app.documents[i]);
    return retval;
  Determines whether snippet can be run given current context.  The snippet
  fails if these preconditions are not met:
  <ul>
  <li> Must be running in Bridge
  </ul>
  @return True is this snippet can run, false otherwise
  @type boolean
SnpCreateTabbedPaletteScriptUI.prototype.canRun = function()
    // Must run in Bridge
    if(BridgeTalk.appName == "bridge")
        return true;
    // Fail if these preconditions are not met.
    // Bridge must be running,
    $.writeln("ERROR:: Cannot run SnpCreateTabbedPaletteScriptUI");
    $.writeln(this.requiredContext);
    return false;
 "main program": construct an anonymous instance and run it
  as long as we are not unit-testing this snippet.
if(typeof(SnpCreateTabbedPaletteScriptUI_unitTest) == "undefined") {
    new SnpCreateTabbedPaletteScriptUI().run();
    Apr 23, 2012 12:29 PM   in reply to Pedro Marques
    The problem is that it is only written to be run from ExtendScript Toolkit.
    You are referencing app.document this has not been created so the script will fail, you would need to use an eventHandler to check if the document has loaded and then it might need a delay.
    See: Adobe Bridge CS5 JavaScript Reference.pdf Page 44
    Apr 23, 2012 3:51 PM   in reply to Pedro Marques
    Yes you could call the script from a menu item..
    Change...
    To:-
    var newCommand = new MenuElement( "command", "SNP Test", "at the end of tools" , "xxxx" );
    newCommand.onSelect = function () {
    You can then start it from the tools menu.
    Dec 19, 2012 12:41 PM   in reply to Pedro Marques
    Where is this file saved at?
    Dec 19, 2012 12:59 PM   in reply to Gonterman1201
    The script is in the sdksamples folder of the Bridge SDK that can be downloaded from..
    http://www.adobe.com/devnet/bridge.html
    To install the script in Bridge.
    Start Bridge
    Edit - Preferences -Startup Scripts
    At the bottom click the "Reveal Button" this will open the folder where the script should be placed.
    Close and restart Bridge.
    Accept the new script.
    Dec 19, 2012 1:14 PM   in reply to Paul Riggott
    I should see SNP Test in tools when I open the program right? I don't think this is working. I am in CS6 on a mac.
    Dec 19, 2012 1:20 PM   in reply to Gonterman1201
    If you have made the above changes, saved it in the correct folder and accepted the script, then yes you should.
    Dec 19, 2012 1:25 PM   in reply to Paul Riggott
    Dec 19, 2012 1:31 PM   in reply to Gonterman1201
    The script is not showing, this could be because you have not closed and re-started Bridge or there are errors in the script, or it has the wrong extension.
    If you click "Reveal My Startup Scripts" it should open the folder and the script should be there.
    Dec 31, 2012 8:03 AM   in reply to Paul Riggott
    Ok I tried it in CS5 and it worked just as you said it would. However it did not work in CS6. That is were I ran into problems. So it maybe that it is erroring in CS6.
    Jan 15, 2013 10:37 AM   in reply to Paul Riggott
    If I delete the tab and then try to run the script again from the tools menu. I get an error on this line.
    Its saying that it is a bad argument list. I am wondering when the tab is deleted what has changed?
    Jan 15, 2013 10:52 AM   in reply to Gonterman1201
    Because it has not been removed from Bridge, it has just been closed, the panel can be shown again by going to :-
    Window - SnpCreateTabbedPaletteScriptUI Panel and selecting it.
    Jan 15, 2013 10:57 AM   in reply to Paul Riggott
    Thanks Paul!
