chandrasekhar439
COM object that has been separated from its RCW cannot be used
Apr 23, 2012 9:51 PM
Tags: #c#
Hi every one,
I am getting the following error "COM object that has been separated from its RCW cannot be used"
private void BtnNew_Click(object sender, EventArgs e)
         TxtBx.Text = string.Empty;
          axAcroPDF1.Dispose();
         scancontinue = false;
         num = 0;
private void BtnSave_Click(object sender, EventArgs e)
         // PnlGeneral.Visible = false;
              BtnScan.Enabled = true;
              if (Isvalid())
                  SqlCommand cmd = new SqlCommand("sp_GenDocuments", con);
                  cmd.CommandType = System.Data.CommandType.StoredProcedure;
                  cmd.Parameters.AddWithValue("@DocName", TxtBx.Text);
                  cmd.Parameters.AddWithValue("@DateCreated", Dtpc.Text);
                  cmd.Parameters.AddWithValue("@DocLocation", paths);
                  //cmd.Parameters.AddWithValue("@DocLocation", path);
                  cmd.Parameters.AddWithValue("@UserName", Login.currentuser);
                  cmd.Parameters.AddWithValue("@imgno",   popuprds.noRecord);
                  if (con.State != ConnectionState.Open)
                      con.Open();
                  int i = cmd.ExecuteNonQuery();
                  if (i > 0)
                      MessageBox.Show("Record inserted", "Message", MessageBoxButtons.OK, MessageBoxIcon.Information);
                      axAcroPDF1.LoadFile(paths); --------> I am getting error here when i tried to load the pdf for second time
                  else
                      MessageBox.Show("Record not inserted", "Message", MessageBoxButtons.OK, MessageBoxIcon.Information);
