I have seen all the replies pertaining to this issue, I can say i tried all kind solutions that are provided in this discussion, and I got stuck up at downloading uninstaller for 32 bit version windows, i am not able to download it.
I am using:
OS: windows 7 Utlimate ; 32 bit OS system type; Browser Type: Firfox 11.
Please provide me soluiton for this.
Kiran
So you have download problems with the uninstaller, or the installer?
Get the uninstaller from http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows. html
Hi Pat Willener,
Let me tell you what I have done before i get to clean install of flash player.
1. I have Unstalled Flash player 10 from control Panel -> Program and Features.
2. Then I have done these steps
Even then I have the same problem again.
At first I did not go for Uninstaller 32-bit because I have done it through Program and Features even then problem exists. So I thought of going clean install process, and it seems Uninstaller is doing nothing......I am attaching a picture of it.... Please I am not sure what I was missing or what is my mistake in here.
I have Norton 360 antivirus s/w.
Please help me out.
Kiran
It looks like you have done everything correctly; uninstalling the ActiveX Control and plugin from the Control Panel should do the same as running the uninstaller.
So after you downloaded and ran the two 32-bit installers, what is your actual problem?
P.S. please note that in the clean install instructions step 2, I have recently added two more files to check in C:\Windows\system32\Macromed\Flash:
After downloading 32-bit installer, I ran the installation and it stops at 47% and says download timeout. I have tried disabling antivirus for 1 hour and still doing the same thing.
I dont see files FlashPlayerApp.exe, FlashPlayerInstaller.exe in C:\Windows\system32\Macromed\Flash:
But I am seeing C:\Windows\system32\Macromed\shockwave10:
Is this the offline installer from Sunil's link above? Can you just try the download again?
Apologies; my mistake: these files would be in C:\Windows\system32
I did downloaded installer from http://get.adobe.com/flashplayer/ it stopped installing at 47% .... and when I was trying the offline installer from http://helpx.adobe.com/flash-player/kb/installation-problems-flash-pla yer-windows.html#Install_in_a_firewall_proxy_server_environment browser keep saying 'connecting' for long time...but not able to see any download process.
Coming to files FlashPlayerApp.exe, FlashPlayerInstaller.exe in C:\Windows\system32, I don't see them.
Some how I managed to download latest version of flash player from other source.... I installed it offline...it worked well this time.
Thanks Pat and Sunil for your support.
Kiran
Hi Kiran,
Could you try downloading from this link?
http://download.macromedia.com/pub/flashplayer/current/install_flash_p layer_32bit.exe
Chris
North America
Asia Pacific
