Ltid
2 baseline grids in 1 document
Apr 24, 2012 5:13 PM
Tags: #cs5.5 #indesign #grid #baseline
I am trying to create a document with two baseline grids. I have set up an A-master with 1 baseline grid but when I set up B-master with a different baseline grid it automatically changes the baseline of A-master (despite not being 'based on' A-Master). Can you please tell me how I can have 2 different baselines in one document? Cheers
    Apr 24, 2012 9:52 PM   in reply to Ltid
    Baseline grid is a document property not a page property. So there is only one main baseline grid for a single document. If you need exceptions you can use a baseline grid that is tied to a text frame.
    Uwe
  • 2 posts
    Apr 24, 2012
    Apr 25, 2012 1:40 AM   in reply to Ltid
    Baseline grid is a document property so you can only set it per document. You can set alternative grid for text box or, for a large publication, you can create multiple indesign publications and combine them in on book.
    Feb 6, 2013 11:12 AM   in reply to Ltid
    Build two separate masters; not based on each other. On each master page you build text frames. On each text frame go to Text Frame Options > Baseline Options > Use Custom Baseline Grid. Your leading of master A text frames can be different from master B text frames. You edit your BodyText paragraph style to Align All Lines to Baseline Grid. You can even link a text frame supplied from A to a text frame supplied by B; have text flowing through them; and the leading will change automatically. So it IS possible to have more than one baseline grid system in a document. You essentially ignore the one setup in preferences.
