Am using Adobe reader 9, now am trying to upgrade my PDF file version from 1.4 to 1.6, while am upgrade the file Adobe Reader will get automatically closed, What is the Problem?
Views
Total Likes
Sorry, but I don't understand what you're trying to do.
Please explain exactly what you're doing.
Views
Total Likes
I have uploaded PDF document properties window screen shot in that I have highlighted pdf version that is 1.4 , but I want to upgrade that pdf version into 1.6 or above, for that am using Adobe Reader 9 to upgrade while upgrading the Adobe reader will get automatically closed the upgrading process will terminated.
Views
Total Likes
I'm still not sure what you're doing and why.
I mean, how are you trying to change the PDF Version of your PDF? Reader isn't able to do such things.
Views
Total Likes
Thanks for reply,
Sorry for miss understanding, Now i will explain you setp by step process
Am going to add Accessbility tag to my PDF document
Step: 1
Adding accessbility Tag to the pdf document
Error Msg:
While the process get started the following error message will appear and adobe reader will get closed
Are you got what is problem?
Views
Total Likes
Well, first of all, you should install the latest updates for your Acrobat (current Acrobat 9.5.1).
If the error then still occurs, it may be that the internal structure of your file is damaged or of a very poor quality.
Then I suggest to run the preflight plugin to try to fix the PDF.
There are tons of fixups in the preflight plugin so you may have to test which does fix your problem.
Views
Total Likes
Thanks for your valuble reply…
Views
Total Likes
Hi radzmar,
I have applied all instruction which is given by you in "Acrobat 10" but still am getting same problem please see the screen shoot as below
Views
Total Likes
Hi radzmar,
One more interesting news am used "Acrobat 6" for adding accessibility tag it was completed successfully without any error message and result is fine.
But I want to known what is the problem in "Acrobat 9" and "Acrobat 10" can you help me?
Views
Total Likes
Interesting.
Can you upload you PDF file somewhere, so I can check it with my system?
Views
Total Likes
There is no option in this reply forum to send file to you so please send me your e-mail id for sending that sample pdf file else give me any other alternative way to send file to you.
Thanking you..
Views
Total Likes
Please use a file sharing service such as Acrobat.com and post the link here.
Views
Total Likes
Download File From Below Link
https://www.drivehq.com/file/df.aspx/shareID9797912/fileID998763156/Test.pdf
Views
Total Likes
sorry but the link has expired.
Views
Total Likes
Good to see you here, Radzmar. I noticed you when I visited the Acrobat forms forum and felt you were bored because you were not challenged. This forum is much, much more engaging and you are naturally thriving (three red boxes). Thank you for helping here.
Views
Total Likes
Sorry for inconvenient please download file from following link.
Views
Total Likes
ok you file was created with Abbyy Fine Reader 10 and seems to have some internal faults.
Even my Acrobat X crashes when I try to add tags.
I could solve the problem by saving the file as optimized PDF through Acrobat before adding the tags.
Views
Total Likes
Hi
I am using Acrobat 9 , am fallowed as per your instruction but still am having the same problem,,,
Instruction :
Error Message:
Views
Total Likes
Here's the file that worked for me.
Views
Total Likes
Thanks for you help,,
I am having one more problem in adding tag to pdf please hlep me see below forums link
Views
Total Likes
