Jusmark123
PHP returning "undefined" variable to flash
Apr 25, 2012 4:33 AM
Tags: #php #as3 #flash_professional #php/mysql #urlvariables
Hello Everyone, I am working on a touch screen POS login interface that takes in a four digit user pin and searches a database. It uses Flash, PHP and MYSQL. I need PHP to return the user name and access level. The AS3 code below is what I have so far, but it doesn't work correctly.
"IntLogin" is the 4 digit pin that is sent to PHP when the user touches login on the GUI.
function onLoginClick(e:MouseEvent):void
          keyLogin.gotoAndStop("KeyDn");
          var loader:URLLoader = new URLLoader();
          var request:URLRequest = new URLRequest("Login.php");
          var variables:URLVariables = new URLVariables();
          loader.dataFormat = URLLoaderDataFormat.VARIABLES;
          request.method = URLRequestMethod.POST;
          variables.login = intLogin;
          request.data = variables;
          trace(request.data = variables);
          loader.addEventListener(Event.COMPLETE, onComplete);
          loader.load(request);
           function onComplete(event:Event):void{
                    var loader:URLLoader = URLLoader(event.target);
                    var variables:URLVariables = new URLVariables(loader.data);
                    txtUser.text = variables.username;
Next is the PHP code which works great in the browser when I implictly give $select a value, returning "username=Walker&access=1"
However, when I run the program from Flash it returns an undefined variable and the end of the PHP file.
<?php # Login.php
require_once ('mysqli_connect.php');
//Connect to the db
if (!empty($_POST['login'])){
          $select = $_POST['login'];
          $sql = "SELECT Last_Name AS name, Access_Level AS level FROM Users WHERE User_ID = '$select'";
          $q = mysqli_query($dbc, $sql);
          if($q){
                    $row = mysqli_fetch_array($q, MYSQLI_ASSOC);
                    $name = $row['name'];
                    $access = $row['level'];
                    echo "username=$name";
  echo "&access=access";
I have have tried debugging the both the PHP and the AS code, but I am stuck. When I trace in AS3 I get the following:
1445
login=1445
undefined
$access";
Please if you anyone can help with this it would be greatly appreciated. I am on a strict timeline and I don't know what to do here.
Jusmark
