nypumrider
Counting empty text fields
Apr 25, 2012 8:25 AM
Tags: #acrobat_x_pro #acrobat-forms #acrobat_10_pro
Hi. I'm looking for a way to count empty text fields in a pdf form and to have the result automatically entered in another field on the same form. Thanks in advance for your help.
  • George Johnson
    Aug 11, 2002
    Apr 25, 2012 9:21 AM   in reply to nypumrider
    What type of fields do you want to check, exactly? Checking for an unchecked check box or radio button is done differently than checking for a blank text field, which is different than an apparently blank combobox/dropdown.
  • George Johnson
    Aug 11, 2002
    Apr 25, 2012 10:57 AM   in reply to nypumrider
    OK, here's a simple custom calculate script for a text field that displays the number of blank text fields that are named "num.1" - "num.10":
    // Custom Calculate script
    (function () {
        // Initialize sum of blank fields
        var sum = 0;
        // Count how many fields are blank
        for (var i = 1; i < 11; i += 1) {
            if (!getField("num." + i).valueAsString) sum += 1;
        // Set this field value to the sum
        event.value = sum;
