ContrinexL
“ Masquer jusqu’a l’animation”(“Hide until the animation”)
Apr 25, 2012 9:19 AM
We bought Adobe In Design  CS5.
Now we have problem with animation SWF file that InDesign CS5 can generate.
When we put “ Masquer jusqu’a l’animation”(“Hide until the animation”) in preview it works correctly, but in SWF file it doesn’t work.
Can you please help us to fix this problem?
    Apr 25, 2012 9:40 AM   in reply to ContrinexL
    Hi !
    contrinexl
    I checked it my end it works fine.
    Try reseting your preferences. migh it will work.
    Apr 25, 2012 10:18 AM   in reply to ContrinexL
    Here is a tutorial about how to reset preferences:
    Apr 25, 2012 1:23 PM   in reply to ContrinexL
    That´s a bug.
    If your animation starts from outside of page area, place animated object to it´s starting point and change animation type to From Current Appearance. Object probably still flashes when user enters the page but nobody can see that since it happens outside page area.
    If your animation´s starting point is inside page area, you have to create some kind of mask for it. If it´s on white page, simple white rectangle will do fine. Make sure that white rectangle is front of the animated object. When you start your animation, fade that mask first to invisible and then start actual animation. That way your animated object flashes behind the mask rectangle.
    You can set the timings in Timing panel.
    Apr 7, 2014 3:52 AM   in reply to ContrinexL
    I was experiencing the same issue.
    When I turned page animations off, it worked perfectly.
    So, I guess it depends on what is more essential (the page turn effect or the animations).
    I am using InDesign CC.
