amd@NC
Text Missing when using PDF Convert but OK when using print PDF
Apr 25, 2012 4:41 PM
I am using Acrobat Pro 9 in Wnidows 7 and Microsoft Publisher 2003.
When I use the CONVERT command to create a PDF - it is missing all of the text on the master page.
If I create the PDF with the PRINT command - everything is OK.
PS: The same Publisher File on another computer using Acrobat Pro 8 works fine -  CONVERT or PRINT and no missing text
I prefer to use convert because sometimes the PRINT command drops some of the hyperlinks.
arniedz@earthlink.net
    Apr 25, 2012 4:45 PM   in reply to amd@NC
    I think you are looking for your answer in the wrong place. This is the
    Adobe FrameMaker forum, not the Microsoft Publisher forum.
    Apr 26, 2012 5:32 AM   in reply to Mike Wickham
    Though this is a framemaker forum however what you can do is ,when you do print as PDF,open the PDF setting box and at the very bottom there is an option that says Convert CMYK to RGB,if thats unchecked please check it or vice versa.
    Regards
    Harpreet.
    Apr 26, 2012 5:46 AM   in reply to amd@NC
    You're posting in the wrong forum, but you already know that...
    In any case, if you're running XP (you didn't supply any info about your environment, which is critical), there's a Microsoft HotFIX patch for PostScript printers such as Acrobat to fix the missing text problem. Do a Google for "Framemaker hotfix missing text" to locate the patch.
