How to create a filter to do a bitmapdata compare and another to do a threshold?
Apr 25, 2012 9:33 PM
Tags: #compare #bitmapdata #threshold
I am new to PixelBender. I have looked at it many times in the last few years, but I can understand how it works.
I want to compare a large number of images and I would like to try PixelBender to create a filter that does the same thing as the
I think PB should be faster.
Also, I want to create a filter equivalent to the AS3 BitmapData threshold() method.
Any suggestions on how I can do those 2 filters?
    May 4, 2012 11:27 AM   in reply to Gil1
    I tried a few different formulations with the pixel bender toolkit and you're right that something is wonky.  I think the scaling in the toolkit might be the issue rather than the flash code itself.  It appears to treat the first and second images differently, which is a bug.
    Have you tried running your filter in a flash program, rather than via the toolkit?
    Chuck.
    May 4, 2012 1:23 PM   in reply to Gil1
    Can you post the actionscript you are using?  The Flash pathway in the PixelBender toolkit seems to be broken for this scenario, but I may be able to debug via your program.
    Chuck.
