miyamojo
Interactive PDF: interactive button limitations
Sep 21, 2012 4:02 PM
Tags: #cs5 #acrobat #pdf #cs5.5 #export #swf #button #interactive #cs6
I don't get what I'm missing here.
I make my buttons
insert multiple pages
choose my button and go to the button flyout
add action on release to go to page 2
but then the button doesn't do anything.
What am I missing?
    Apr 26, 2012 12:03 AM   in reply to miyamojo
    Buttons will not work in the Indesign , you have to export the file in the Interactive PDF and then check in the PDF.
    Apr 26, 2012 12:25 AM   in reply to miyamojo
    You can use Window>Interactive>Preview panel for quick testing. It´s meant for previewing SWF files before exporting, but many of the PDF´s interactive features are also supported, like Go To Page actions. You can test your file that way before exporting PDF.
    Apr 26, 2012 2:12 AM   in reply to miyamojo
    Which PDF viewer are you using?
    Also When you hover your mouse on the button , does it change into hand like icon?
    Apr 26, 2012 2:22 AM   in reply to Manish-Sharma
    That´s good point, only Adobe Reader and Acrobat fully supports PDF´s interactive features. For instance Mac Preview which is very popular among mac users does not support all interactivity.
    And another thing you may want to check is that you have made correct setting while exporting (see image)
    And one more thing is transparency. You can´t have any transparent objects (extracted PSD image, object with opacity or blendmode, object with effect like drop shadow) on the top of button.
    It may kill the interactivity.
    Apr 26, 2012 10:20 PM   in reply to miyamojo
    did you choose File > Export >  PDF (InteractiveI? Not PDF (Print)?
    If you did I doubt that you may have some transparancy issue. Try to create new layer and make sure it is above all the other layers. Choose the layer and create (or cut/paste some exisiting) button to that layer. Then export pdf and test if that particular button works...
    And it may also be good idea to trash preferences...
    Apr 26, 2012 10:37 PM   in reply to miyamojo
    Sorry, How could I miss it at first place......
    The action "Go to Page" will work only in SWF not in PDF......check the image below for actionsUntitled.png
