Save using PDF Optimizer
Apr 26, 2012 7:59 AM
    Apr 26, 2012 7:59 AM   in reply to Community Help
    PDF Optimizer is not working properly!!!!
    Apr 26, 2012 12:27 PM   in reply to bbfl333
    You need to be more specifc about the issue.  What is the error or exact behavior that you are experiencing?  Unless you describe it, those of us on the Forums can't really help.
    Oct 11, 2012 9:15 PM   in reply to Community Help
    I am having a problem with Optimizer and with Save As Reduced File Size on documents that I scanned on my HP All-in-One Scanner.  I open the document and use the Save As dialogue and nothing happens - it stays the same size.    I'm using Acrobat X 10.1.4.  Any ideas??
    Oct 12, 2012 12:32 AM   in reply to Larry Sugarman
    These functions aren't magic - they can only reduce when there is some slack to cut out. Maybe the scanner is doing a good job.
    Is the file size exactly the same, to the number of bytes? Does the modification date change?
    How about if you fiddle with image settings?
