the tools panel is missing and give me an 'internal error occured' warning window.
the ctrl + F2 doesnot change anything. i've tried the uninstall reinstall, but that doesnot help either.
the display was set to the highest setting, and i did not find any colapsed icon to expand or drag in.
and the property inspector is just blank.
can any body help?
thank you
In Firefox, try looking under Tools > Add-Ons to open the Add-ons Manager window, and then look under Extensions. At least that's where I think you'd find it—but you may not have it installed. I have to plead ignorance here: I have the Firebug extension (which I never really use), but not Flashbug or FlashFirebug, which I guess are extensions of Firebug that are geared towards Flash.
http://blog.coursevector.com/flashbug
http://www.o-minds.com/products/flashfirebug
Again, this may not be the answer, but it seemed worth suggesting.
thank you, again.
i've tried it.
but it seems doesnt solved my problems.
When i compare folders in CS3 and CS5, the required folder of my CS5 seems to be more 'emptied' than the other.
if i compare it to the required folder at Photoshop, in fireworks there are no default tool preset, no defaults of anything.
i am stuck. ![]()
Sorry to hear that! Problems like yours are a bit out of my area of expertise... Is your version of Fireworks recent enough that you still qualify for tech support from Adobe?
Adobe Support and Customer Service
800-833-6687
Monday–Friday, 5am–7pm PST
Fireworks Help: http://helpx.adobe.com/fireworks.html
I'm wondering if the problem might be related to a bad preferences or user configuration file. Do you have another user account on your computer? If you did, I'd log into the other user account, open Fireworks and see if the same problem occurs. If the tools panel appeared, then I'd imagine that it's that type of issue. (Then again, your original post referred to an "internal error" warning dialog, so maybe not...). The following Adobe Help page provides some information on where to find the configuration and preference files:
http://help.adobe.com/en_US/fireworks/cs/using/WS4c25cfbb1410b0021e63e 3d1152b00db4b-7ffc.html
To avoid losing settings you'd rather preserve, I'd probably move any suspect files into a folder on your desktop, rather than trashing them. Then you could restore them later, if it turned out they were not causing the problem.
Oh, wait! I just found a more detailed set of instructions for troubleshooting Fireworks preferences:
http://helpx.adobe.com/fireworks/kb/restore-preferences-fireworks-cs5. html
As for the Required folder, I'm not sure where that is... Is that application-specific? I have older versions of Fireworks and Photoshop, and they may not have the same folders that your version does.
Hope this helps somehow!
many many thanks for your kindly attention.
i dont know which one did i do that make it right today.
all i know is that i've tried so many ways, and finally end up fixed.
yes, it is fixed.
i guess, i do install it right after the last uninstalling. i ve update the video driver as well, though the GPU at my photoshop is still can not be enabled.
but, the first frustrating problem was solved. beautiful.
again, thank you.
North America
Asia Pacific
