BS_Cowboy
Tables and Drop Down Lists
Apr 28, 2012 5:59 AM
Tags: #dynamic #table #tables #es2 #drop_down_list #8.2
This is my first time using LiveCycle Designer (8.2)
I've tackled quite a few things thanks to the information I've found in these forums, but I have reached my complexity limit.
I am trying to create a survey form that follows a process map with sub-process maps.
Just to provide an idea of magnitude, one process map has eleven sub-process maps.
I created a dynamic table with the ability to add and delete rows on a flowed page.
The first row first column contains a drop down list.
For each selection in the drop down list, the form requires eight inputs.
Currently, I just copied the dynamic table for each subprocess.
Each sub process map will have a running calculated total based on two inputs and a cost based on input.
The overall process map will have the same.
The entire section should seperatly show a sum total.
I don't really know what would be best, but was thinking something along these lines:
based on the selection in the drop-down-list, if someone selects one of the sub-process maps
the row changes to allow the drop-down-list to be the one associated with that subprocess and
the two running totals show up and remain at the bottom of the table.
Only problem, is I have no idea how to do this.
I have tried making the tables invisible, but they still show the input areas of the input boxes.
Anyone feel like helping me figure this out?
Also, isn't there a way I can populate a drop down list using EXCEL?  I don't want to manually input thousands of process titles.
Oh, I don't have any XML capabilities, I am not connected to a server or any database, and everything runs at the client.
    May 2, 2012 4:52 AM   in reply to BS_Cowboy
    I assume you are refering to "white space" left in your form when setting to invisible.
    Rather than set to invisible, set to hidden, but due to complexity of form that you have shown you may need to start from scratch and set subform "content" to flowed once you have arranged all your tables/buttons etc. I would have thought that javascript would be more appropriate for working out your calculations.  Take a look http://www.youtube.com/watch?v=LNki6UwJFeA regarding form flow - it may help
    May 2, 2012 5:35 AM   in reply to BS_Cowboy
    Well - that question kinda blew my brain!!! I'd keep it as simple as poss, using just the one dropdown list to hide/set visible other items/be it sub forms, other drop down boxes, fields etc.
    I have found the ability to dynamicly hide subforms that contain other questions sets an invaluable tool in Livecycle
    Good luck!
