Hi all.
Re this product:
http://help.adobe.com/en_US/livecycle/9.0/sd_releasenotes.htm
Does this work in 4.6? It worked fine in 4.5, but I'm not having much luck getting it up and running in 4.6. Adter installation, I can see the connect to Livecycle DS option under Data, I can log in to the livecycle server and search for services, but when I try to pick a service and hit next, nothing happens, no errors or popups.
Anyone else see this?
Thanks much
Checking the eclipse log, it would appear that a noSuchMethodError is being thrown:
!ENTRY org.eclipse.ui 4 0 2012-04-30 11:36:49.633
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NoSuchMethodError: com.adobe.flexbuilder.DCDService.core.ServicesFactory.newFlexService(Ljava/lang/String;)Lcom/adobe/flexbuilder/DCDService/core/IFlexService;
at com.adobe.flexbuilder.services.lcservice.LCService.introspectService(Unknown Source)
at com.adobe.flexbuilder.services.lcservice.LCServiceWizard.nextPressed(Unknown Source)
at com.adobe.flexbuilder.DCDService.ui.wizard.ServiceWizardDialog.nextPressed(ServiceWizardDialog.java:95)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:428)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at com.adobe.flexbuilder.DCDService.ui.wizard.ServiceWizard.show(ServiceWizard.java:191)
at com.adobe.flexbuilder.DCDService.ui.wizard.ServiceWizard.createService(ServiceWizard.java:153)
at com.adobe.flexbuilder.dcrad.views.ServiceExplorerView$1.handleEvent(ServiceExplorerView.java:533)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendSelectionEvent(Widget.java:1094)
at org.eclipse.swt.widgets.Link.wmNotifyChild(Link.java:1071)
at org.eclipse.swt.widgets.Control.wmNotify(Control.java:5534)
at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:1896)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:5086)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4584)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4985)
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:2424)
at org.eclipse.swt.widgets.Link.callWindowProc(Link.java:172)
at org.eclipse.swt.widgets.Widget.wmLButtonUp(Widget.java:2057)
at org.eclipse.swt.widgets.Control.WM_LBUTTONUP(Control.java:4912)
at org.eclipse.swt.widgets.Link.WM_LBUTTONUP(Link.java:909)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4565)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2530)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3752)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.java:108)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
