Celery007
Errors when saving to SMB mounts (a thorough examination)
May 1, 2012 5:29 PM
Tags: #photoshop #error #lion #mac #osx #saving #snow #leopard #smb
Several of the users I support have reported the following issue when trying to save files to the network from Photoshop. I have found several threads about this on both the Adobe forums and the Mac forums. However, in most of the threads the information provided is incomplete or does not control for enough variables. And the result is that Adobe seems to blame Apple, and Apple seems to blame Adobe. So blame aside, here is information that I hope helps Adobe solve the issue at hand.
When saving to a mounted SMB point, users report one of two errors:
  • Could not save <filename> because of a program error
  • Could not save <filename> because write access was not granted
I can replicate the issue on:
  1. Lion 10.7.X with Photoshop CS 5
  2. Lion 10.7.X with Photoshop CS 5.1
  3. Snow Leopard 10.6.X with Photoshop CS 5
  4. Snow Leopard 10.6.X with Photoshop CS 5.1
Details:
  1. We have only seen this error in Photoshop.  << Adobe has seen the same problems in several other applications >>
  2. I have not tested out whether the issue applies to any other products in the CS suite.
  3. At first I thought the issue might have to do with permissions, but it does not. I have reapplied permissions and the issue persists. And it affects all users, including Domain Admins, such as me, who have no R/W restrictions at any level.
  4. The issue only occurs when Finder is in a view that shows a thumbnail/preview of the image.
  5. Switching Finder to list mode resolves the error in all scenarios
  6. So far I can replicate this with any file on any mount on any of our servers
  7. It only occurs on mounted network points (ie - if I move the files locally, no errors are encountered)
For the following tests, presume the following:
  • Source folder: smb://example/source/folder
  • Target folder: smb://example/source/folder
  • Target sub-folder: smb://example/source/folder/sub
Here are the steps I tested:
  1. Opened the file problem_file.psd.
  2. A warning pops up prompting me to resolve a font vector issue, I chose "Update"
    Note: that this error does not pop up for every file, just the original file I worked with, but this warning has nothing to do with the errors being received
  3. Moved a layer so that there would be a change to save
  4. Clicked save
  5. Received the error: "Could not save <filename> because of a program error"  << probably related to the known MacOS bug on SMB, or a known Finder/thumbnailing bug >>
  6. The original file, problem_file.psd, is *DELETED* (very problematic)  << Known MacOS bug in SMB service, Apple is working on it >>
Then I tested with multiple variations of the following to conrol for things such as layers or font issues:
  • To eliminate the source file being the issue, I used a .png file that I had created locally with the OS-X screen shot keyboard command. This eliminated layers and fonts as issues.
  • In step 2 I chose to not update the font vector issue
  • In step 4 I tried saving as different file types (.jpg, .png, .gif)
  • Prior to step 6 I flattend the image to eliminate fonts and layers. This eliminated layers and fonts as issues.
  • Prior to step 6 I flattened the image, duplicate the image, closed the original (without saving), and attempted to save the new duplicate. This eliminated layers and fonts as issues.
Each variation still resulted in "Could not save <filename> because of a program error" and resulted in the deletion of the source file.
Next I controlled for saving image previews:
  1. Photoshop -> Preferences -> File Handling
  2. Under File Saving Options -> Image Previews, I set it to "Never Save" previews
Now when I repeated the tests from aobve, I receved the error "Could not save <filename> because write access was not granted".
Next I controlled for .DS_store files:
  1. Disabled .DS_Store file creation on remotely mounted points.
  2. Deleted the .DS_Store file for the source folder
  3. Verified that .ds_store files were not being created on remotely mounted points
  4. Ran the tests above, and the issue persisted: "Could not save <filename> because write access was not granted"
Now I decided to test sub-folders:
  1. Created a target sub-folder.
  2. Repeated the test above, and its variations, but saving the problem_file.psd to the target sub-folder.
  3. Still received one of the two errors, depending on the variation, but the source file is no longer deleted. This make sense because saving in another directory is really a "save as", and one would not expect safe saving (talked about more later) to affect source files in this scenario.
Sort of a Solution:
  1. Open the file from Finder
  2. Depending on the Finder view, Finder shows a thumnail of the image
  3. Go back to Finder and select a different file
  4. Make changes to the file
  5. Save the file
  6. No error is received
This is when I discovered that the error only occurs when Finder is in a view that shows a thumbnail/preview of the image. Further testing of Finder show that in Cover Flow the error only occurs for the selected image. For example:
  1. Cover flow shows thumbnails/previews of files: A, B, C, D, E
  2. Open A
  3. In Cover Flow select file B
  4. The thumnails of of files A, B, C, D, E are still visible
  5. Make a change to the open file
  6. Save the change
  7. No error is received
This shows that Finder is treating the thumbnails/previews of unselected files different than selected files.
An Interesting Twist:
If from the last scenario with Cover Flow...
  1. Open file A
  2. Go back to Finder and select a different file
  3. Then make a change and attempt to save to the target sub-folder
  4. Receive the error "Could not save <filename>" because of a program error.
Discussion:
Photoshop does something called safe saving.
  1. Photoshop saves the current document to a temporary file with a unique name
  2. Photoshop deletes the original file << this is incorrect >>
  3. Photoshop moves the temporary file to a file with the name of the original file that was deleted in step 2  << incorrect: the temp file replaces the original with an OS call to a function that is supposed to be an atomic operation >>
However, you can see that "safe saving" is misnamed, because while the original is deleted, Photoshop does not appear to be correctly ensuring that permissions exist to allow the temporary file to be ranemd or that the temporary file was renamed without error. Photoshop is either:
  • Not checking for the error  << yes, it is >>
  • Checking for the permissions and not catching the error  << incorrect >>
  • Checking for the permissions and giving an error to generic to discern the exact problem from. << also incorrect >>
Somewhere there is a conflict (perhaps a race condition) between:
  • Photoshop creating the temporary file
  • The server applying permission to the newly created temporary file
  • OS-X reporting the file has been created
  • Photoshop deleting the original file
  • Photoshop saving the new file
  • Finder updating the thumbnail of the file
As I've shown here, the problem doesn't seem to reside fully with Apple or fully with Adobe. Hopefully this post provides enough information for some clever engineer to create a fix.
My information about safe saving is from an Adobe mod on a previous thread regarding this issue << and copied incorrectly, plus added bad assumptions>>. He detailed the process and also explained that Photoshop uses OS APIs to create and delete the files during safe saving. If his details are accurate, it seems that a temporary fix would at least change the safe saving process to the following:
  2. Photoshop moves the original file to a temporary backup file (original-file-name.original-extension.bak)
  3. Photoshop moves the temporary file to a file with the name of the original file moved in step 3
  4. Photoshop checks to make sure that the temporary file has been succesfully renamed
  5. If the temporary file has successfully been renamed, it deletes the backup file from step 2 OR if the temporary file has failed to be renamed, the backup is returned to its original file name
  6. The appropriate error message, if any, is displayed
A Few Sources:
    Apr 30, 2012 4:44 PM   in reply to Celery007
    You got several details wrong.
    And it sounds like you are describing 2 known MacOS bugs:
    1) The OS fails when creating or swapping files on SMB servers, and this happens more often on files that have a resource fork.
    2) The Finder/QuickLook/Thumbnailing holds a file busy when it should not, causing program errors or file is busy errors.
    We did as much as we could to work around these issues in Photoshop CS6 - after spending a lot of time debugging the OS issues and working with Apple.
    Apple is still working on proper fixes within the OS.
    Apr 30, 2012 9:57 PM   in reply to Celery007
    Adobe has warned not to save over a network for more than a decade. Why is this thread even here?
    May 1, 2012 5:30 PM   in reply to Celery007
    OK, I made your correction to your statement #1.
    May 12, 2012 3:07 PM   in reply to Celery007
    I tried the newest 10.7.4 OS X Lion and CS 6 and the problems aren't solved.
    The whole thing only works reliable if "Finder" has no window open showing the containing directory of the file.
    Aug 8, 2012 6:46 PM   in reply to Celery007
    Hi all,
    I too am having trouble saving over to our file server connected via SMB.
    (CS6, Mountain Lion)
    What fixed it for me was going to the File Handling preferences, File Saving Options, and setting Image Previews to "Never Save"
    Hope this works for the rest of you having this issue.
    Cheers,
    Lorrytron.
