OdditiesofAllDegrees
Is there at all a simple way to set the export size of a SWF?
Apr 30, 2012 3:54 PM
Tags: #help #swf #flash_cs5.5 #animation
Need Help!
I created an animated banner for class, using a standard size.  It ended up way to small, but all the element and text animation is done.  I can easily change the document size, but everytime I try to enlarge the elements, they pixilate and lose all visual integrity (not to mention its enough work to resize between all the tweens that I might as well start over).  However, resizing the actual SWF output proves the elements can handle being a larger size without any pizilation or degrading - it looks great much larger than the initial export.  Is there at all a simple way to just have Flash 5.5 export the same banner SWF at a larger size?   Please help!
  • kglad
    Jul 21, 2002
    May 1, 2012 6:49 AM   in reply to OdditiesofAllDegrees
    you can load (dynamically) your banner into another swf and resize it in the main (loading) swf.
