add attribute to a XML node at a specific position
May 2, 2012 5:42 AM
Tags: #as3 #xml #attribute
I have this XML :
var myNode:XML = <node attribute="123"/>
I know how to add an attribute to the node :
myNode.@otherAttribute = "abc";
But this adds the attribute to the end. What if I want to add it as the first attribute ? I would like to have :
<node otherAttribute="abc" attribute="123"/>
I know it is possible to add a child node to a specific position with insertChildAfter() or insertChildBefore() but I don't know if it's possible for an attribute.
    May 2, 2012 7:52 PM   in reply to eprevot123
    there's no native method for this, maybe you should create some functions for this. just like
    private function setAttribute(node:XML, name:String, value:String, index:int = -1):void
        var attrs:XMLList = node.attributes().copy(),
            l:int = attrs.length();
        if(index == -1 || index > l - 1)
            node.@[name] = value;
        else
            delete node.@*;
            var idx:int = 0;
            for (var i:int = 0; i < l + 1; i++)
                if(i == index)
                else
                    var attr:XML = attrs[idx];
                    node.@[attr.name()] = attr.toString();
                    idx++;
    and use it like this:
    setAttribute(myNode, "otherAttribute", "abc", 0);
