John Hawkinson 5,514 posts
Jun 25, 2009
InDesign/InCopy 7.5.3 is out [ANN]
May 2, 2012 11:44 PM
Tags: #cs5.5 #release #updates #notes #7.5.3 #7.5.3.333
You can tell CS6 is getting close.
Adobe has released InDesign and InCopy (and InDesign Server) version 7.5.3.333.
Release notes at http://helpx.adobe.com/indesign/release-note/release-notes-indesign-cs 5-51.html
(well, linked from http://www.adobe.com/support/documentation/en/indesign_incopy/releasen otes.html#indesignCS55753 if you want to compare InDesign and InCopy and InDesign Server).
Changes from 7.5.2.318 to 7.5.3.333:
Architecture / Document
  InDesign unexpectedly quits when performing certain copy/paste operations. [3073952, 2941163]*
  When opening files from a newer version of InDesign, non-meaningful errors about missing plug-ins are shown rather than a clear indication that the file is from a newer version. [2944763]*
  Degradation in performance when moving objects when display is set to High Quality [3128109]*
  InDesign unexpectedly quits when recovering a file on product restart. [3100953]*
Graphics
  White stitching line in JPEG export with certain placed images scaling percentage and JPEG export resolution [2987040]*
  Redraw performance for ID CS5 is slow compared to CS3. [2910574]*
  Poster: From Current Frame' option in the Media will not restore the poster from that frame after re-linking. [3097841]*
  Reduced transparency support for TIFF files from Photoshop CS6 [3073238]*
  In certain drag and drop scenarios, URLs are getting changed in InCopy/InDesign CS4, CS5.5 [3054805]*
Installer
  Uninstall/Reinstall removes Bridge's "Place>In InDesign" menu item. [3079235]*
Import / Export
Wrong page number on export book to PDF [2940448]*
INX / IDML
  Tab override gets reset in INX/IDML [2827174]*
  Master applied incorrectly when opening IDML file [3114965]*
  Legacy versions fail to read ID CS6 files that contain files with new Pantone Plus colors. [3119501]*
Layout
  Inconsistency in loading and exporting a linked image from INDD [3017929]*
  Strange offset occurs between two pages on same spread [3080049]*
Print / PDF
  InDesign unexpectedly quits when exporting to PDF with text variables [2866963]*
  Note inside document table with text variable causes InDesign to quit unexpectedly on export to PDF/IDML. [3089441]*
  Unable to navigate document if TOC is on master page. [2907482]*
  Text appears misplaced in certain cases when DataMerge is used to export [2939067]*
  InDesign hangs or quits unexpectedly during certain package and preflight operations. [2982454]*
Scripting
  Problem copying stories via VBScript when called through an application [3059225]*
  Unexpected shutdown when JavaScript is executed with InDesign followed by closing of document. [3021908]*
Text
  Using Smart Layout with Linked frames causes InDesign to unexpectedly quit in certain cases. [3085379]*
  Fonts not loading from different locations. [3013562]*
  InDesign quits unexpectedly with certain fonts when balancing columns [3099740]*
  Fonts of the same family but different type behave unexpectedly on IDML round trip. [3114961]*
  Certain documents go into infinite loop when adjusting frame size [3113902]*
  Incorrect glyph selection with certain Indic fonts when using specific virama and joiner character sequences. [2849232]*
  Broken spanning columns cause issues with Text Wrap & Keeps Options [2958674]*
UI
  Folio Builder and CS Review's SWFs will not render when '<' is present in doc filename [2971572]*
  InDesign CS5.5 quits unexpectedly on deleting unused swatches using small view option [2987294]*
XML
associatedXMLElement returns 'NULL' for a merged cell in table. [2946288]*
InDesign Server Only
CCommandLineArgs::ProcessArgsLate will cause product to hang in certain cases when used with LogToApplicationEventLog [2988814]*
InDesign Server quits unexpectecly when running spell checker on certain documents. [2935990]*
Document installed fonts get locked on Windows. [2890001]*
    May 3, 2012 1:44 AM   in reply to John Hawkinson
    Hey, what about this one!
    This needs to be retro-fixed for all existing versions, all the way back to InDesign 1.0!
    It's unimaginable this particular issue had to persist for more than a decade, leading to frustration and bewilderment of literally thousands of users, and hundreds upon hundreds of posts in this forum alone.
    May 3, 2012 2:05 AM   in reply to [Jongware]
    That would be nice, but realistically it's not likely to happen, and wouldn't you rather they fixed something more important that's still broken, like footnote imporvemnets, or wonky Word import? Bad error messages will become self-limiting as time goes on.
    May 3, 2012 2:19 AM   in reply to [Jongware]
    Nice and helpful fix!
    Marijan (tomaxxi)
    May 3, 2012 2:27 AM   in reply to Marijan Tompa
    Hah -- perhaps all it does is run my Javascript before opening a file ...
    May 3, 2012 2:42 AM   in reply to [Jongware]
    Probably...
