Hi All
I am working with an ID script in CS3 and I am trying to write some script (to add to an exsiting scipt that I am using) that will change small caps to all caps for some ID documents I am converting.
Sorry it's probably very easy to do but I'm fiarly new to using scipts!
Thanks for any help with this.
You really need to provide a litte more basic information. For example: which scripting language are you using?
You say you're trying -- show us your attempt so we can guide you.
How is the small-caps applied? Local formatting or character style? Would just changing the spec of the character style do the job (if so, why not do it without a script?) or is there some filter you want to apply to single out particular instances?
Dave
Hi All
Sorry as I said I'm new to using and writing scripts!
The script (Java script) I am using was supplied to me by someone else and I am mainly just tweaking it.
The script is being used to mainly find character and paragraph styles and change them from one style to another.
As I have a lot of files with quite a few different styles to change the script is saving heaps of time.
The small caps that I am trying to change are in a character style and I need to if possible change them to normal caps that isn't a character style in most circumstances although there are places where they need to be a certain bold or italic character style.
The script is mainly using GREP search to find and change the various character and paragraph styles and the script I have tried so far is:
| grep | {appliedCharacterStyle:"Chapter Small Caps (A+B)"} | {appliedStyle:"All Caps"} | {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false} | Apply body Text Indent para Style to all. |
The small caps need to be changed in several different character styles.
I hope this makes it a bit clearer what I'm trying to do
North America
Asia Pacific
