Importing one Pdf document into another.
May 3, 2012 5:12 AM
Tags: #reference #xobject
I am trying to import one Pdf-document into another using a Reference XObject. I am looking at thePDF- specification, and I thought I was doing things the right way, but its not working. The PDF-specification doesen't have an example of how to do this, only an explanation.
Below is the PDF-file I am testing with (if anyone can be bothered looking at it   ). The file embeds another pdf-file, and is supposed to show a part of the embedded file at a certain position.
Again, if anyone can be bothered looking at my PDF and see if they can see what I am doing wrong here I would appreciate it.
(There is nothing wrong with the embedded file itself...)
PDF-file embedding another PDF-file and using a Reference XObject to display the embedded file:
%PDF-1.5
1 0 obj
/Type /XObject
/Subtype /Form
/BBox [0 0 100 100]
/Ref <<
/F (4fa27162e72547a00771606.pdf)
/Page 1
endobj
2 0 obj
/Type /Filespec
/EF <</F 3 0 R>>
endobj
3 0 obj
/Type /EmbeddedFile
/Length 854
stream
%PDF-1.5
1 0 obj
/Length 334
stream
q
1 0 0 1 128.10769621539 70.591821183642 cm
1 0 0 1 0 0 cm
1 0 0 1 0 0 cm
1 0 0 1 0 0 cm
1 0 0 1 -128.10769621539 -70.591821183642 cm
/DeviceCMYK CS
1 1 1 1 SCN
/DeviceCMYK cs
0 0.89 0.89 0.05 scn
0.2743205486411 w
2.743205486411 M
0 J
0 j
-1.9202438404877 -2.6517653035306 260.05588011176 146.48717297435 re
h
B
Q
endstream
endobj
2 0 obj
/Type /Page
/Parent 3 0 R
/Resources <<
/Font <<>>
/XObject <<>>
/MediaBox [0 0 255.11811023622 141.73228346457]
/Contents [1 0 R]
endobj
3 0 obj
/Type /Pages
/Kids [2 0 R]
/Count 1
4 0 obj
/Type /Catalog
/Pages 3 0 R
endobj
xref
0 5
0000000000 65535 f
0000000010 00000 n
0000000401 00000 n
0000000568 00000 n
0000000624 00000 n
trailer
/Size 5
/Root 4 0 R
startxref
679
%%EOF
endstream
endobj
4 0 obj
/Length 322
stream
q
1 0 0 1 93.268986537973 71.826263652527 cm
1 0 0 1 0 0 cm
1 0 0 1 0 0 cm
1 0 0 1 0 0 cm
1 0 0 1 -93.268986537973 -71.826263652527 cm
55.961391922784 45.628651257302 74.615189230378 52.39522479045 re
W n
1 0 0 1 55.961391922784 42.062484124968 cm
74.615189230378 0 0 55.961391922784 0 0 cm
/XobjectPDF1 Do
Q
endstream
endobj
5 0 obj
/Type /Page
/Parent 6 0 R
/Resources <<
/Font <<>>
/XObject << /XobjectPDF1 1 0 R >>
/Contents [4 0 R]
endobj
6 0 obj
/Type /Pages
/Kids [5 0 R]
/Count 1
7 0 obj
/Type /Catalog
/Pages 6 0 R
endobj
xref
0 8
0000000000 65535 f
0000000010 00000 n
0000000144 00000 n
0000000238 00000 n
0000001172 00000 n
0000001551 00000 n
0000001738 00000 n
0000001794 00000 n
trailer
/Size 8
/Root 7 0 R
startxref
1849
%%EOF
    May 3, 2012 5:45 AM   in reply to DDahlgren
    A Reference XObject is used for referring to ONE PAGE of another PDF – usually a completely separate file, though it could also be embedded.  It is not a well supported feature of PDF – it requires Acrobat/Reader 9 or later.  I am not aware of any other PDF viewer that supports it ☹.
    It’s extremely hard to read/follow what you post.  If you want a PDF looked at – please post a link to an actual PDF.
    May 3, 2012 6:11 AM   in reply to DDahlgren
    PDF is a binary format - even tough sometimes it looks like straight ASCII
    when you open it in an editor. This means that we cannot really do anything
    with what you've posted. If I would save it and open it in my debug tool,
    it would report a corrupt file.
    Reference XObjects are a pretty tricky subject, and a lot of planets have
    to perfectly align to make them work. Take a look at this blog post from
    four years ago that explains what you need to do in terms of setting up
    Reader or Acrobat, but also has links to sample files in the comments:
    https://blogs.adobe.com/ReferenceXObjects/2008/06/reference_xobjects_1 .html#comments
    Karl Heinz Kremer
    PDF Acrobatics Without a Net
    khk@khk.net
    http://www.khkonsulting.com
    May 3, 2012 6:58 AM   in reply to DDahlgren
    PDF is a binary format. The most important piece in a PDF file is the cross
    reference table. It contains byte offsets to the different objects in a
    file. If you insert just one space (which in a true ASCII file will not
    change much), you are making all byte offsets after the insertion point
    invalid. They now all point to something different than the start of an
    object.
    Because there is no standard about how line endings are encoded in text
    files, every time may add (or subtract) a byte - depending on what computer
    system and what editor you use to convert your PDF to fake-ASCII, and then
    again what I use to try to convert it back to PDF. If you are using a
    Windows system and I'm using a Mac, the cross reference table gets
    corrupted. And that's even before the web server does it's magic and
    potentially adds data.
    If you want somebody to look at your file.
    Have you looked at the post I linked to? The settings in Acrobat are
    important. You need to enable Reference XObjects, AND you have to declare
    the directory where your target file is stored as trusted.
    From what I can see in your PDF code, you are doing a whole bunch of cm
    operations. You may want to consolidate all those into one operation. I
    have not done a detailed analysis, but you could potentially shift your
    data off the page. Keep it simple and see if that makes a difference.
    Karl Heinz Kremer
    khk@khk.net
    May 3, 2012 7:23 AM   in reply to DDahlgren
    And as Karl explained, we don’t know what line ending format (Mac vs. Win vs. Unix) you used, so that the number of characters could be different thus breaking the xref.
    Bottom line – if you don’t post an actual PDF file, we are unable to review it.
    May 3, 2012 8:15 AM   in reply to DDahlgren
    That link does not work.
    How many pages do you have in your reference document? You are trying to
    pull in the second page. If this is only a one page document, it will of
    course not work. Remember that page numbers in the PDF world are zero
    based. Assuming that your referenced document does indeed have a 100x100pt
    page as indicated by your BBox statement, the following content stream
    should give you a correctly placed reference XObject:
    q
    1 0 0 1 0 0 cm
    /XobjectPDF1 Do
    Q
    Again, you need to make sure that your directory is correctly configured in
    Acrobat's preferences, and that you have Reference XObjects enabled for all
    documents (and not just PDF/X5, which is the default).
    Karl Heinz Kremer
    khk@khk.net
    Dec 19, 2012 8:35 AM   in reply to DDahlgren
