mike_hurley_1
Bug? Using 1 NetConnection for 2 publish streams: second NetStream always sent as NET_STATUS target.
May 3, 2012 7:05 AM
Tags: #flash #as3 #rtmfp #swf #netstream #action_script_3 #event #as3.0 #actionscript3 #publish #actionscript_3.0 #netconnection #p2p #direct_connections
Using RTMFP, I make a connection to the server with NetConnection.
I publish NetStream A directly to the server (like you would for RTMP).
I publish NetStream A_direct so that RTMFP P2P can play it after publishing with DIRECT_CONNECTIONS.
These NetStreams share the same NET_STATUS handler function.
When I get the NetStream.Publish.Success events, the event.target is always set to the second NetStream.
The event message is correct however (it properly says which stream is now published).
I tried this with debug Flash player for 10.3, 11.0, and 11.2.
Message was edited by: mike_hurley_1
