• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Why don't I have the merge with background option in version 5.5?
New Here ,
May 03, 2012 May 03, 2012
In ealier versions I could right-click on the object and then select merge with background, I no longer have this option, where did it go?
Views
930
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Hello and welcome to the forum,
What are you trying to merge with background of which type of slide? The option is certainly still there, just used it even on master slides it is possible.
Lilybiri
Votes
Translate
Translate
Report
Report
New Here ,
Thanks.
Just a .gif file on a slide.
Votes
Translate
Translate
Report
Report
Community Expert ,
Check the Properties panel, if this slide has 'Use Master Slide Background' checked in the General accordion, then the Merge will not be available because you have to merge this object in the Master slide with its background. Hope this makes sense?
Lilybiri
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Thank you, that was it!
Michaela Pulte
Senior HR Specialist
402-351-8802
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi there
Usually the option is not available because the slide is using a Master Slide. Clear the Master Slide option and you should see the option re-appear on the menu.
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7, 8 or 9 within the day!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
Votes
Translate
Translate
Report
Report
New Here ,
Thanks for the reply, at the risk of appearing dumb, what do you mean by
clear the Master Slide option?
Michaela Pulte
402-351-8802
Votes
Translate
Translate
Report
Report
Resources
Help resources
