how do i /save/ the correct orientation?
May 3, 2012 7:04 PM
i am opening a pdf, orienting it to the /correct/ orientation and saving it and then close it - when i open it the orientation is incorrect again.
how do i fix this so it WORKS?
  • George Johnson
    Aug 11, 2002
    May 3, 2012 9:09 PM   in reply to hotwheels222
    You can either rotate the pages or rotate the view. When you rotate the pages and save, they will stay rotated. When you rotate the view and save, it will revert back to the original view when it's next opened.
    May 4, 2012 7:00 AM   in reply to George Johnson
    The rotate pages is typically found under the Documents menu. The rotate icon you might be using on the toolbar is the rotate view and is only good for the current session.
    May 5, 2012 2:23 PM   in reply to hotwheels222
    You need to use the Tools menu on the right-hand side of the window, and
    there go to Pages - Rotate.
    May 6, 2012 4:38 AM   in reply to hotwheels222
    Are you using Acrobat or Reader. If Reader, then you can not save the rotation changes.
  • George Johnson
    Aug 11, 2002
    May 6, 2012 10:05 AM   in reply to hotwheels222
    You can add the icon that try67 pointed you to to the Quick Tools bar: http://help.adobe.com/en_US/acrobat/pro/using/WS58a04a822e3e50102bd615 109794195ff-7feb.w.html
    The biggest problem I see with this is the button is not all that cute.
