• Global community
    • Language:
      • Deutsch
      • English
      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
Exit
0
Can't retrieve ip address
Guest
May 04, 2012 May 04, 2012
I trying to get a persons ip address using  <cfoutput>#cgi.REMOTE_ADDR#</cfoutput>, but all i'm getting is 0:0:0:0:0:0:0:1.Anyone know why and a better why to get it?
Views
2.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Do you have a firewall or other traffic management device between you and the outside world which might be routing external traffic onto an internal network?
Check to see if this returns anything useful:
GetHttpRequestData().headers["X-Forwarded-For"]
Adam
Votes
Translate
Translate
Report
Report
Guest
I only have a router for a firewall. I used a site www.whatismyip.com and it gets it no problem.
Votes
Translate
Translate
Report
Report
Guide ,
That's localhost in IPv6 is it not? Are you running CF locally?
Votes
Translate
Translate
Report
Report
Guest
Yes running cf on my computer to test all cf applications.
Votes
Translate
Translate
Report
Report
Guide ,
In which case that's probably correct and it should work when you put it live. As I say, that's localhost in IPv6.
Votes
Translate
Translate
Report
Report
Guest
I needed to add the persons ip to this application to make sure they don't submit a vote twice (site i'm working on). So since this doesn't work locally i have to come up with another way.
Votes
Translate
Translate
Report
Report
Guide ,
Well to be clear - it *does* work locally - it's giving you the IP address of the client; it just happens that's localhost. You shouldn't redesign your entire application just because it doesn't work in this one case.
Votes
Translate
Translate
Report
Report
LEGEND ,
Or indeed because it does work in this case.
Adam
Votes
Translate
Translate
Report
Report
Community Expert ,
May 05, 2012 May 05, 2012
LATEST
You have yet to respond to Owain's IPv6 remark. I hope you are now convinced that 0:0:0:0:0:0:0:1 is actually the localhost IP. That is, it is the same address as 127.0.0.1, but then in IPv6 notation. Your computer is the only localhost. You can therefore safely assume that CGI.REMOTE_ADDR will return the IP address of other client computers out of your domain.
Message was edited by BKBK
Votes
Translate
Translate
Report
Report
Resources
Documentation
