I need to compress about 1,000 jpg images and I'm using the "save for web" feature in Photoshop 7 but I'm running into problems because my file names are very long and its cutting them off. I found the workaround by editing the output settings and unchecking the "Mac OS" box under "Filename Compatibility". However, the problem is that the default settings do not stay like this once I hit OK and I end up having to uncheck the Mac OS box for each and every file. Is there a way to permanently change the default settings so I can do batch processing for all my images? Thanks!
When you are at the "save for web" window, there is a little down arrow at the far top right corner of that window (optimize menu). Click on that, go to Edit Output Settings. In the second drop down, select "Saving Files". Create your custom workflow, then save that preset. When you start saving your images, make sure to use this preset when given the option.
Hi Shan-Dysigns,
I tried this and saved the preset as "Output Settings" and one for "Custom" but the problem is that everytime I open a new jpg file, I have to choose this option from the edit screen which causes issues when I record an action for batch processing since it does not recognize the change in the output settings and thus saves the file with a shortened name. My goal is to change the core "Default Settings" to uncheck the Mac OS box, so I tried to save it as "Default Settings" and receive this error (attached). Now, when I go back into the settings screen, the "Default Settings" preset is totally missing. How to I reset the preferences to regain this "Default Settings" preset? Thanks.
If you record an action and uncheck the Mac Os box does the setting not record in the action?
Also if your on windows vista or 7, you might have run ps 7 as an administrator to get those settings to stick.
(just running ps 7 once as an administrator should do, then you can run it normally after that)
Look in:
C:\Program Files (x86)\Adobe\Photoshop 7.0\Presets\Optimized Output Settings
for the Default Settings.iros.
If it's gone look in:
C:\Users\Your Name\AppData\Local\VirtualStore\Program Files (x86)\Adobe\Photoshop 7.0\Presets\Optimized Output Settings
(i think a reinstall is required to get back that preset if it's gone and you want the default)
As far as i can tell you would have to save a new Default Settings.iros to make ps 7 use the custom file compatibilty settings all the time.
You could save a new setting named Default Settings.iros to your desktop and then copy it to:
North America
Asia Pacific
