mirian
Permanent Error #2044: Unhandled ioError:. text=Error #2032: Stream Error. URL:
May 6, 2012 2:41 PM
Tags: #error #flash_cs5.5 #sandbox #sandboxing
Flash CS5.5, worked fine before, but now getting Permanently getting: Error #2044: Unhandled ioError:. text=Error #2032: Stream Error. URL within Flash IDE, have no problem published in HTML with F12. content is shown, of course works fine on the server
Code is very simple:
var loader:URLLoader = new URLLoader();
loader.addEventListener(Event.COMPLETE, loadXML);
loader.load(new URLRequest(sameResultsonAnyAddress))
It's not crossdomain problem
It's not spelling problem
Something wrong within Flash Pro IDE when testing or debugging,
I switched off my McAfee firewall, didn't helped.
Really confused, can't guess what might be the problem.
  • kglad
    Jul 21, 2002
    May 7, 2012 6:15 AM   in reply to mirian
    when testing, the path to your load target is relative to the swf.  when using an html file to embed your swf, the target is relative to the embedding html.
    if that doesn't solve your problem, copy and paste a sample of real (not pseudo) code and attach screen shots of the directory that contains your recently published swf.
    May 7, 2012 10:07 PM   in reply to mirian
    Hi Mirian ,
    I tried out with your action script code and it works perfectly fine on my system. I get the entire xml trace in the output window.
    However , if I tried this on a system with no internet connection i.e the link - http://forecast.weather.gov/MapClick.php?FcstType=dwml&lat=42&lon=-85& unit=1 , itself is not working , I get the same output as you are getting -
    Error opening URL 'http://forecast.weather.gov/MapClick.php?FcstType=dwml&lat=42&lon=-85& unit=1'
    Error #2044: Unhandled ioError:. text=Error #2032: Stream Error. URL: http://forecast.weather.gov/MapClick.php?FcstType=dwml&lat=42&lon=-85& unit=1
    at Untitled_fla::MainTimeline/frame1()
    Let me know if this helps.
    Thanks and regards,
    Sudeshna Sarkar
    Adobe Flash Professional Team.
    Mar 6, 2013 3:31 PM   in reply to mirian
    I have experience this error. Try checking the textfield behavior if it was format as multiple line. Changed it to single line and it will work.
    It works on me and when I selected it back to multiple line it gives me the same error.
