So I'm trying to setup CF 9 on my Mac running OS X Lion and, surprise surprise, the installer won't run. I've run into this wonderful problem on Windows before, but don't remember how I solved it there nor do I know it it would be the same problem. Just to be clear, it's not a failed installation process. The process doesn't even get started, the installer doesn't run at all. I realize maybe they don't support Lion, but even then, something should happen in the installer saying the OS is not supported or something.
I checked the Console logs and this is the error that's coming up:
macbook com.apple.launchd.peruser.501[94] ([0x0-0x2a6ba69].ColdFusion 9 Installer[96113]): posix_spawn("/Users/tmessier/Downloads/ColdFusion 9 Installer.app/Contents/MacOS/adobe_cf", ...): Permission denied
No idea what that really means, I always run installations from this same directory and never had a problem. I'm guessing maybe it's trying to copy the installation files from the archive somewhere and executing from that directory and that fails, but not sure how to remedy this problem.
Any help would be appreciated.
I've installed ColdFusion well over 100 times on numerous operating systems and don't recall ever having a problem. So I find your bitterness hard to take. I also get frustrated with people who immediately get indignant about a problem like this, particularly when trying to do something that is clearly unsupported. CF9 is not supported on Lion, so try not to get so frustrated with Adobe when you are trying to do something that they never claimed you should be able to do.
That said, I will try to help.
First, are you aware that Lion does not come with Java? Did you install it?
Second, have you check the execute permissions on the installer. Who owns the file? It doesn't matter if you've run installers from the directory before, files can have their own permission. Perhaps something with your got buggered. Worst case, you could just try setting it to 777 (don't forget that a .app is a package, so you need to recurse file permission changes. chmod -rf 777 ColdFusion\ 9\ Installer.app).
You could always try downloading the file again.
Hope that helps. If it doesn't you might also want to check this: http://superuser.com/questions/361475/com-apple-launchd-com-apple-laun chd-peruser-error
Jason
Jason, I had actually removed the somewhat stronger wording in the message soon after posting it and well before your reply. It was pointless and counter productive, so I guess I saw your point before you even made it! The solution you pointed out (changing permissions) works perfectly, many thanks for that. Kind of wish a solution was easier to find for this problem, seeing as it doesn't really appear to be a Lion problem, more like a Unix one. I searched the hell out of it before posting here and got nowhere. Seeing as I've absolutely never run into this installing anything else, really makes me wonder what the hell happened.
Hey Adam, I did read a bunch of things, but seems like people have run into different problems. Most of the things I saw were not installer issues. Who knows, maybe my search words ended up not getting the right thing, but at least the problem's now solved. Hopefully somebody else searching for a solution to this will have an easier time now.
North America
Asia Pacific
