native process execution problem in mac os
May 7, 2012 1:11 AM
hi,
     In my flex application i have to get mac serial  number as a unique id for each system . On searching i got one terminal command to get serial number. For that i have  run terminal command through flex native process. I have set supportedprofile as <supportedProfiles>extendedDesktop desktop</supportedProfiles> in app xml. But when i install and run application on mac terminal is getting opened but command is not executing. I couldn't trace out the problem.  I could execute cmd in windows and that worked . Please help me to findout a solution................... The test code is adding below
private var process:NativeProcess
=new NativeProcess();
protected function windowedapplication1_creationCompleteHandler(event:FlexEvent):void
                // TODO Auto-generated method stub
                if(NativeProcess.isSupported) {
                    Alert.show("Yes NativeProcess");
                    process.addEventListener(ProgressEvent.STANDARD_OUTPUT_DATA, onOutput);
                    process.addEventListener(ProgressEvent.STANDARD_ERROR_DATA, onIOError);
                    process.addEventListener(IOErrorEvent.STANDARD_OUTPUT_IO_ERROR, onIOError);
                    process.addEventListener(IOErrorEvent.STANDARD_ERROR_IO_ERROR, onIOError);
                    process.addEventListener(NativeProcessExitEvent.EXIT,onIOError);
                    var info:NativeProcessStartupInfo     =     new NativeProcessStartupInfo();
                    info.executable                               =     new File("/Applications/Utilities/Terminal.app/Contents/MacOS/Terminal");
                     /*  var startupArgs:Vector.<String>    =     new Vector.<String>();
                         startupArgs[0]                              =    'system_profiler |grep "r (system)" ';
                         info.arguments                              =    startupArgs;*/
                    //Alert.show(String(info.arguments.length));
                     process.start(info);
                    process.standardInput.writeUTFBytes('system_profiler |grep "r (system)" '+ "\n");
                }else
                    Alert.show("No");
            protected function onIOError(event:IOErrorEvent):void
                Alert.show("Error");
            protected function onOutput(event:ProgressEvent):void
                var processID:String            =    process.standardOutput.readMultiByte(process.standardOutput.bytesAvai lable,"");
                Alert.show("Path : " + processID );
I have tried to set arguments but didn't execute......
Message was edited by: aswathykrishnan
    May 7, 2012 5:31 AM   in reply to aswathykrishnan
    Unfortunately I am at work with a PC, so I can't test on my mac.
    Where does the program stop? Does it go into the "Yes native" branch and then you get the "Error" alert? Or you get the "No" alert right away?
    Jun 15, 2012 5:22 AM   in reply to aswathykrishnan
    Hello Aswathy, these days I'm also coding an application which uses AIR NativeProcess and I required to open the MacOS terminal with some parameter/commands. I also eventually turn to the AppleScript, but I considerably new to the AppleScript, yet trying to findout a way to passing parameters (the command argument) to the AppleScript; the appleScript I managed to open but not passing the argument. Can you please help? here's my some probable codes for the application:
    My appleScript is:
    #!/bin/bash
    on run argv
              tell application "Terminal"
                        set currentTab to (do script) & item 1 of argv
              end tell
    end run
    I've packaged the appleScript as an Application (Contract.app) and here's my Flex code:
    var npInfo : NativeProcessStartupInfo = new NativeProcessStartupInfo();
    npInfo.executable = new File( "/Applications/Contract.app/Contents/MacOS/applet" );
                                  var arg:Vector.<String> = new Vector.<String>;
                                      arg[0]="ssh santanu@172.25.1.22";
                                  npInfo.arguments = arg;
                                  process = new NativeProcess();
      process.start( npInfo );
    Thank you.
