Introducing: Scale Strokes
May 7, 2012 2:54 AM
Tags: #script #ui #scale_strokes
  Latest reply: Mathias17, Jan 17, 2014 10:01 AM
Replies 1 2 Previous Next
  • Mathias17
    Feb 20, 2012
    May 7, 2012 3:45 PM   in reply to Jacob Bugge
    Neither way gives access to the extension: all that happens either way is that I get a file ending in .js.txt, and it still appears as a text file.
    It's entirely possible to name a file:
    Aunt Illy.pdf.txt
    In the above case, it's still a text file. ".PDF" is simply in the name (not extension) and is ignored. Only after the last period in the file's total name is the actual extension designated.
    You must verify you have 'Show File Extensions' turned on.
    Again, per the above case - without it, you don't see ".txt". So a file called: "Aunt Illy.pdf.txt" will look like "Aunt Illy.pdf" to you.
    Jongware, makes a great point. I recommend always keep file extensions showing. It's worth it.
    May 7, 2012 5:21 PM   in reply to CarlosCanto
    Well the script works great and I see no reason why Adobe should not pick this one up and incorporate it into the stroke panel.
    Thank you and well done.
    Cheers!
  • Mathias17
    Feb 20, 2012
    May 7, 2012 5:58 PM   in reply to CarlosCanto
    For the record, you can paste the textual contents of Carlos's [AKA Cronos of Tartarus] script into notepad and just save it as *.js  -OR-  *.jsx. It is just a text file afterall.
    (use the "Raw Paste Data" section at the bottom of the OP's linked page)
    But anyway, what this really adds is the real-time slider, and an easy percentage input, right? You just click in the Weight field and add *1.5 to scale to 150% if wanted. So "2pt*1.5" becomes 3pt.
    May 7, 2012 8:16 PM   in reply to Mathias17
    Very nice, Carlos.
    By the way, you are exceeding the limit:
    May 7, 2012 10:07 PM   in reply to tromboniator
    BTW it works in CS 6 and even takes on the CS interface.
  • Pierre Courtejoie
    Jan 11, 2006
    May 8, 2012 1:41 AM   in reply to Jacob Bugge
    Jacob. On windows, do browse to a folder. On Vista and 7, you might need to click on ALT to show the menus.
    There, click on Tools>Folder Options>View and uncheck "Hide extensions for known file types" I do it as a security measure also, otherwise, I don't know what I'm clicking on.
    May 8, 2012 3:19 AM   in reply to Pierre Courtejoie
    With tooltip....
    Without...
    CS6 / Mac
    May 8, 2012 3:46 AM   in reply to Mathias17
    Thank you very much, Mathias, and Pierre.
    (You may have to first unhide file extensions for known filetypes in your Windows Exporer folder options.)
    Indeed. I finally found it in the Control Panel, after overlooking the option in the Tools dropdown.
    Unfortunately, Carlos:
    And Theunis,
    Jacob, you must be a trusting soul,
    Indeed.
  • Mathias17
    Feb 20, 2012
    May 8, 2012 7:36 AM   in reply to CarlosCanto
    Hi Mathias, not really...well, for a Selection of 1, yes, or for multiple selections that will end with a uniform line weight. But the script works best with multiple selections with multiple line weights, all strokes will scale proportionally.
    Oh! Ok, yeah great!
    I've failed to say thanks for this, so far. So, thanks for makin' it!
    May 8, 2012 6:56 AM   in reply to CarlosCanto
    CS6 Screenshot
    I see Scott already did post a screenshot he's a traditionlist and made his lighter.
    May 8, 2012 9:15 AM   in reply to CarlosCanto
    Carlos – Firefox 13 (beta)
    edit: It's the same in Safari. Mac 10.6.8
    May 8, 2012 9:24 AM   in reply to CarlosCanto
    This is just to say GREAT job Carlos!
    works fine on Windows 7
    May 8, 2012 2:21 PM   in reply to Jacob Bugge
    Jacob,
    talking about using dialogs in conjunction with Javascripts in AI 10 you are clearly lost.
    CS 1 was the first version that introduced that capability.
    You're lost.
    May 8, 2012 2:30 PM   in reply to Kurt Gold
    You're lost.
    I know, Kurt.
    May 9, 2012 11:18 AM   in reply to CarlosCanto
    Carlos,
    Thank you for the offer, but I have no specific need for it.
    May 12, 2012 9:11 PM   in reply to CarlosCanto
    Hi Carlos, I have tried to modify your script to use a "palette" UI. It now looks like below:
    I don't know it's useful or not. Anyway, here is the link: http://pastebin.com/3jZ0PjKk
    May 13, 2012 6:02 AM   in reply to moluapple
    Moluapple,
    Very useful indeed! As I mentioned in the thread that gave rise to this, a palette version would be much more elegant; and it is. With your palette version, the flickering from the redraw is gone, so the slider works like a slider should. You can change the selection without dismissing the window.
    Moreover, though, I now (at long last) have an example of a functioning AI javascript palette--something I've been looking for ever since first dinking around with AI javascript dialogs.
    (I've run this in CS3, by the way, so it works at least that far back.)
    Thanks.
    JET
    May 13, 2012 7:00 AM   in reply to JETalmage
    You are welcome JETalmage, it's me the one need to say thanks, I learn a lot from you in this forum.
  • Mathias17
    Feb 20, 2012
    May 13, 2012 7:39 AM   in reply to moluapple
    Excellent, moluapple. Thanks for doing that.
    May 13, 2012 6:40 PM   in reply to CarlosCanto
    Carlos,
    I think I learned this from the Adobe Illustrator CS3 FlashPanel Sample, and I have using this method for quite a long time.
    May 14, 2012 2:43 AM   in reply to CarlosCanto
    Hi all,
    That's interesting, the doc is using a bridgeTalk but you should be able to call the function directly. Or this is either related to Illustrator or CS3- versions. I did use a few ScriptUI/SWF projects with ExternalInterface but never needed to use a bridgeTalk. Anyway I am very fond of theses technologies
    Best,
    Loic
    hht://www.loicaigon.com
    hht://www.loicaigon.com/blog
    May 14, 2012 5:18 AM   in reply to Loic_aigon
    Hi Loic,
    With Indesign that's true, but sadly not Illustrator, even with CS6.
    May 14, 2012 5:21 AM   in reply to moluapple
    Hi Mark,
    Ok I ignored it thx for the info !
    Loic
  • Mathias17
    Feb 20, 2012
    May 15, 2012 8:05 AM   in reply to moluapple
    Can I recommend a slight revision to this?
    Enable Up and Down arrow keys when caret is in the Scale text field, which would increase or decrease the Scale value by 1. Also, Shift+Up and Shift+Down as well (which would bump the percent by 10% of course).
    May 15, 2012 9:15 AM   in reply to Mathias17
    Yes, if its possible to implement Mathias suggestion, this will be great. Meanwhile the closest alternative is to press and hold with the mouse the left or right buttons of the scroll bar. However I noticed that doing so with the panel will change the value but not give a real time feedback of the change and will update the screen redraw after releasing the mouse while ith the original non-modal window it does update in real time feedback but it flickers.
    Nevertheless, great job guys, you rock!   I find this script as a better alternative to a assign a precise stroke weight even when using a single path. The predefined increments available in the Illustrator's Stroke panel are not very practical for me. I often need fine tuning of strokes in the range of 0.25 to 3 points and I end up spending a lot of time typing trial and error values in that range to get precisely the desired weight. Your script makes this much easier and interactively.
    May 15, 2012 10:15 AM   in reply to CarlosCanto
    That will be great Carlos, very much appreciated.
  • Mathias17
    Feb 20, 2012
    May 15, 2012 10:17 AM   in reply to CarlosCanto
    Very cool, Carlos. You're softening some of the CS6 dismay with this one.
    Jan 17, 2014 7:34 AM   in reply to CarlosCanto
    Carlos,
    I have saved as you indicated, but still don't see it on my illustrator. Where exactly would I find it? I checked on the stroke panel, and also on the object/transform/scale and don't see it.
    Have I done something wrong?
    This is the location where I saved it....
    Jan 17, 2014 7:56 AM   in reply to CarlosCanto
    Thank you so much for replying so fast!
    Yes, I restarted illustrator, and since it didn’t work I restarted my computer. But again… where should I see this feature now? On the stroke panel, or the transform, or somewhere else?
  • Mathias17
    Feb 20, 2012
    Jan 17, 2014 8:11 AM   in reply to Danitica
    File > Scripts
1 2 Previous Next
Actions
