• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
tilelist and xml
Explorer ,
May 07, 2012 May 07, 2012
I am unable to load pics from xml to TileList
I tried to add through Array & addItem , but both are not working
below is code , when xml is loaded
function clipsXmlLoaded(event:Event):void
    clipsXml = XML(clipxmlLoader.data);
    trace(clipsXml);
    for(var c:int = 0; c<clipsXml.length ; c++ )
        //clipsArray.push ({label:"" , source:String(clipsXml.clip)});
        clips_list.addItem({source:String(clipsXml.clip)});
            trace(clipsXml);
    trace("clips");
    //clips_list.dataProvider = new DataProvider(clipsArray);
TOPICS
ActionScript
Views
740
Translate
Translate
Report
Report
Community guidelines
community guidelines
Contributor , May 08, 2012 May 08, 2012
clipsXml.length() gives only 1. Thats your loop is not executed. First retrieve your nodes length in xml file then you get the output.
Votes
Translate
Translate
LEGEND ,
The Array class is not the same as the XML class.  You might need to revise your code to agree with the methods of the XML class.  You seem to be using them as properties.   Try...
    for(var c:int = 0; c<clipsXml.length(); c++ )
        clips_list.addItem({source:String(clipsXml.clip.text())});
Votes
Translate
Translate
Report
Report
Explorer ,
this Line not works in loop
but when I use outside the loop IT WORKS like this :
clips_list.addItem({source:String(clipsXml.clip[1])});
clips_list.addItem({source:String(clipsXml.clip[2])});
clips_list.addItem({source:String(clipsXml.clip[3])});
loop is not working , but it tracing path also fine
Votes
Translate
Translate
Report
Report
Contributor ,
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
somtime Minor error creates so much time wast
Votes
Translate
Translate
Report
Report
