Flash CS6 Trial Bug
May 7, 2012 11:13 AM
I've just downloaded and installed Flash CS6 Professional in Trial Mode. Everything seems to be okie except the bug "Unable to load external importer C:\Program Files\Adobe\Adobe Flash CS6\en_US\Configuration\Importers\PhotoshopReader.dll" when i tried to import any image to Stage or to Library. Note that there is a file named PhotoshopReader.dll (ver 12.0.0.481) in the path above. I tried to install on another computer but the same error. How to fix it? Thanks!
    May 7, 2012 9:05 PM   in reply to Flash Course
    I need some more information to resolve this issue
    Please add these information.
    1. OS (xp, vista or win 7)
    2. Any  windows patches are installed in your system.
    3. Any photoshop products installed in system (Photohsop, Photoshop elements, Lighroom or Photoshop Album)
    4. System configuration (Hardware manufacture , Dell, sony or IBM)
    May 8, 2012 2:50 AM   in reply to Flash Course
    I tried to import the image file in same applications machine. It’s working as expected. Please try two more things
    1. Open same file in any image editing software, check whether it’s corrupted
    2. Open and save the file in image editing application and import in library
    Please mention the format of image and which software it’s created.
    May 8, 2012 3:44 AM   in reply to Flash Course
    Hi ,
    To help us investigate this issue , I want you to perform the following steps :
    1. Open DependencyWalker(depends.exe)application. This is a free utility.
    2. Open AdobePSL.dll and then PhotoshopReader.dll.
    3. In each case check what errors you are getting while loading these dlls and send the errors to us.
    We will get back as soon as we are able to figure out the problem.
    Thanks and regards,
    Sudeshna Sarkar
    May 9, 2012 3:56 AM   in reply to Flash Course
    Thanks for the logs.
    We are currently looking into the errors. Will keep you updated.
    Thanks and regards,
    Sudeshna Sarkar
    Adobe Flash Professional Team.
    Aug 14, 2012 9:10 PM   in reply to sudeshna sarkar
    Was an answer ever found for this? I have the same issue. I installed the trial, but recently upgraded to Creative Cloud license, yet the error still happens anytime I try to import anything, even after updating Flash.
    Update: I uninstalled and reinstaleld. Same error.
    Nov 30, 2012 10:55 PM   in reply to sudeshna sarkar
    I have same probelm , any solution?
    Feb 5, 2013 3:28 AM   in reply to Flash Course
    I'm having the same problem, except that my CS6 is not a trial version. The error occurs as soon as I select File/Import.
    Apr 1, 2013 8:40 AM   in reply to sudeshna sarkar
    Been getting that error as well:
    Like everyone else here I have checked the path and the photoshopreader.dll file is there.
    The system, an old  Dell Optiplex GX280 with P4, 3ghz CPU and 2 gb RAM is running Windows XP, SP3
    and has Adobe Photoshop CS2 installed.
