How to create multiple multifields under a multified
Avatar
Level 1
I have a requirement to create a nested Multifield in AEM6.3, in which there should be two multifields inside. i have tried and able to get one multifield inside one multifield values by following "aem-experience.blogspot.in". Also tried creating multifield using resourceType = "granite/ui/components/coral/foundation/form/multifield" for child multifield's and for the parent multifield with resourceType = "granite/ui/componentsfoundation/form/multifield". Here child values are stored as NODE_STORE properly. But the  parent values are not, so the multifield is not able to re populate the values. Please Help me with this issue. This is not working if u use ACS COMMONS/custom JS. I have tried giving coral multifield to parent also, then the dialog is not able to submit.
XML for multifiled with two inner multifields,
   <vIL
                                                jcr:primaryType="nt:unstructured"
                                                sling:resourceType="granite/ui/components/foundation/form/multifield"
                                                fieldLabel="V">
                                                <field
                                                    sling:resourceType="granite/ui/components/foundation/form/fieldset"
                                                    name="./vIL">
                                                    <layout
                                                        sling:resourceType="granite/ui/components/foundation/layouts/fixedcolumns"
                                                        method="absolute"/>
                                                    <items jcr:primaryType="nt:unstructured">
                                                        <column
                                                            sling:resourceType="granite/ui/components/foundation/container">
        <sV
        sling:resourceType="granite/ui/components/coral/foundation/form/checkbox"
        checked="{Boolean}false"
        fieldLabel="Select Vendor"
        name="./sV"
        text=""
        value="{Boolean}true"/>
        <vRE
        sling:resourceType="granite/ui/components/coral/foundation/form/textfield"
        fieldLabel=""
        name="./vRE"/>
        <sDL
        fieldLabel=""
        name="./sDL"
        text=""
        <dOIL
        fieldLabel=""
        name="./dOIL"/>
        <sCL
        fieldLabel=""
        name="./sCL"
        text=""
        <cL
        fieldLabel=""
        name="./cL"/>
        <sIL
        fieldLabel=""
        name="./sIL"
        text=""
        <iNL
        fieldLabel=""
        name="./iL"/>
        <sSL
        fieldLabel=""
        name="./sSL"
        text=""
        <sL
        fieldLabel=""
        name="./sL/>
        <sWS
        sling:resourceType="granite/ui/components/foundation/form/checkbox"
        fieldLabel=""
        name="./sWS"
        text=""
        <mI
        sling:resourceType="granite/ui/components/coral/foundation/form/multifield"
        composite="{Boolean}true"
        fieldDescription=""
        fieldLabel="">
        <field
        sling:resourceType="granite/ui/components/coral/foundation/container"
        name="./mi">
        <oIL
        allowBlank="{Boolean}false"
        fieldDescription=""
        fieldLabel=""
        name="./oIL"/>
        <rL
        fieldDescription=""
        fieldLabel=""
        name="./rL"/>
        <vCU
        fieldLabel="l"
        name="./vCU"/>
        </items>
        </field>
        </mI>
        <cD
        fieldDescription=""
        fieldLabel="">
        <field
        name="./cD">
        <iDL
        fieldLabel=""
        name="./iDL"/>
        <iDV
        fieldLabel=""
        name="./iDV"/>
        </items>
        </field>
        </cD>
                                                            </items>
                                                        </column>
                                                    </items>
                                                </field>
                                            </vIL>
Screenshot for child multifield node storage,
Krishna
Message was edited by: Krishnasumanth Manchikalapati
Avatar
Administrator
Here is an excellent post :- Nested multifield in AEM 6.3 + sightly  by anoopo70540109
// whole code is provided. Please use and modify as per your need.
and AEM – Coral 2 multifield with acs-aem-commons JSON_STORE | Adobe Experience Manager Blog
Kautuk Sahni
Avatar
Level 1
Thanks for help Kautuksahni, but these links i have already tried and doesn't worked for me .They worked for nested field. but not for nested composite even i made some changes. still got the issue.
Avatar
Level 1
Thanks for help smacdonald2008, but this link i have already tried and doesn't worked for me. it worked for nested field. but not for nested composite even i made some changes. still got the issue.
Avatar
Level 10
Those are the only docs that i know of. If you follow the one that i listed - what is happening?
