Hello everyone! Is there any way to abort or hide this "standard progress bar" when exporting high-quality prints through scripts?
I added a custom progress bar to my script that took too long but I sometimes realize that the two palettes are shown at the same time? It would be possible?
That's the palette I'm using! If someone has another functional model I am very grateful
myPrs = new Window('palette', 'Batch Processing');
myPrs.orientation = 'column';
myPrs.alignment = 'right';
myPrs.ProcessHead = myPrs.add('statictext',[40,0,260,25], "Batch Processing...");
myPrs.Process = myPrs.add("progressbar",[40,40,260,65]);
myPrs.Label = myPrs.add('statictext', [150,75,200,120], "0%");
myPrs.Process.value = 0;
var LENGTH = 4;
myPrs.show();
for(i=0;i<1;i++){
var PrCounter = 0;
ProgressBar(++PrCounter, i+1 , 1);
Function1();
function ProgressBar(v, x, y){
var value = (Number(v) / LENGTH) * 100;
myPrs.Label.text = Math.round(value) + " % ";
myPrs.ProcessHead.text = "Batch Processing... [" + x + "/"+ y + "]";
myPrs.Process.value = value;
function Function1(){
// my code
I have native progressbar here: Magic scripts for Photoshop (Delete all empty layers faster)
Anyway since version 1.1 it's too fast and I almost never see progress bar but it should be here and should be cancelable.
I don't rememeber excatly but progressbar may return true/false value. And you will store this value in variable. And in "for loop" you are checking if true/false and if so, you will break loop with break keyword.
Problem with native progressbar is that it will not let you do some kind of actions like transform.
Hi Jarda Bereza what I need in fact is to hide or delete the native progress bar! thus displaying only my custom bar progress palette!
I love these scripts "Magic scripts for PS" mainly the "
Have you listed the directory for System fonts? C:\Windows\Fonts
reply to removed(?) comment:
Hmm scripting native progressbar could override progressbar bundled with certain action. I didn't tested it but it would make sense.
Yes these scripts are mine. What is your request?
Jarda Bereza First of all, I want to congratulate you on your beautiful work, and second on thanking you for sharing it with us. As regards my request:
In my workflow I do not work with system fonts. I usually saved all my installed fonts to all adobe programs at:
C / Program Files / Common Files / Adobe / Fonts /
You could do a little modification on ""
That way, only my work sources will be included in the list.
Could you make this change for me? Thank you
As for progress bar:
I have not been able to do what you suggested because I am still an apprentice for scriptting and my level of knowledge does not allow me to do so. If you have a practical example and can have it, I will be eternally grateful!
smithcgl9043167​ How works this folder? Are fonts placed here automaticaly available in Photoshop?
Hi Jarda Bereza! That's right! If you add any source in the "Program Files / Common Files / Adobe / Fonts /" folder, the font automatically becomes recognized by any Adobe software.
Note!
Before you need to create the "Fonts" folder within the "Program Files / Common Files / Adobe" path then add your preferred fonts.
I will explore if script can see this fonts from script or only system installed fonts.
I believe you will! Thank you.
