My company just setup digital signatures using Entrust for the certificates. I cannot figure out how to send for DIGITAL signature when I select SEND for Signature. I have read the user guide and it says I must prepare the form by selecting digital signature field bu the only option I see is e-signature. When I send the document, the user is only able to sign using an e-sig, the digital signature isn't an option unless they open the document themselves with Adobe Pro DC, insert their token, and select certificates from the tools menu. I would rather not do this manually! I'm sure there is a way to send and track multiple with digital signers.
Hi Kstewart,
As per the description mentioned above, you want pdf to get signed by multiple users using a certficate signature, is that correct?
Please refer to the steps given in the following link discussing the similar workflow:
Get multiple signatures on a single document |
Send PDF documents for signature, Adobe Acrobat Reader DC
Thank You,
Shivam
Hi Kstewart,
Thank You,
Shivam
