String Data Compression
Dec 11, 2008 Dec 11, 2008
Is there a way to take a long string and compress it into a much shorter string?
Here's an example string, a comma-delimited set of values:
cd,1111-1111-11-1,d120700000a72cbj001c,46808598,60,1,030308,060108
I'd like to shrink it down to a 10-12 character string that a user can input.
Does anyone know of any tools to perform this?
Advanced techniques
821
Advocate ,
You want to limit the user to enter a string that is of 10-12 characteres?... Or else you want to shrink a long input into a shorter string?...
I want to shrink that string into something shorter.
Then provide that shortened string to the user who would then enter it into a form and I would expand it out to it's original length and values and process the comma-delimited values.
Advocate ,
Then, you might need this "Abbrevate" udf,
http://cflib.org/udf/abbreviate
What it does is, it output the string to your desired length with ellipsis at the end.. (Search Azadi's post in some old threads...)
HTH
That doesn't seem to do it.
Here's my predicament:
This string represent a coupon
All of the necessary information is in that string.
Current process involves tucking that away in a barcode, so it is simply scanned into the system.
The new process that I'd like to put in place is to send the user a code via email that they can enter into a form.
I am trying to get away from maintaining a massive database with all of these coupon codes and attaching a unique identifier to each record that the use would enter. It's just a lot of data I don't want to store in a database. So I'd like to compress that string to a unique value and just translate it.
> HTH
Actually I think grotycom is asking for tool(s) that would take a long
string and encrypt|encode it into a shorter string that can be used for
input and then decrypted|decoded back into it's original string.
I have done this with the hash() function to store long strings as
unique shorter strings, but it does not allow for the reverse decoding
back to the original string. I am not aware of any tools that do this,
but I'm sure they are out there somewhere.
> HTH
Exactly - Hash won't work.
Advocate ,
Why can't you use the "Encrypt" and "Decrypt" functions?..
quote:
Originally posted by: Daverms
Encrypted strings are longer and definitely not user friendly.
but if you are sending your users an email - why not include a simple
link they can click on in the email?
that link would have a url parameter - either your original full string
or an encrypted one - something like:
http://somesite.com/somepage.cfm?c=cd,1111-1111-11-1,d120700000a72cbj001c,46808598,60,1,030308,06010...
[in the email tell your users to click on the included link or
copy/paste it into their browser]
somepage.cfm is your form page - make it insert the #url.c# variable
into appropriate form field automatically, or parse #url.c# first and
insert parts of the string into appropriate fields - basically do
whatever you need to do with that string.
[obviously also include some checks to make sure url.c is there and is
in correct format and the values it contains are valid]
hth
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com/
Dec 13, 2008 Dec 13, 2008
The output of the encrypt function includes mostly special characters. Not
very user friendly. It also outputs double and single quotes that have to
be account for also.
Jeff
"grotycom" <webforumsuser@macromedia.com> wrote in message
news:ghrh6l$jsf$1@forums.macromedia.com...
> Hi,
Dec 12, 2008 Dec 12, 2008
Doesn't a barcode also have a number? Why dont you give them the number
associated with the bar code?
Adam
Participant ,
Dec 15, 2008 Dec 15, 2008
I don't know of any ZIP-like functionality for text strings, and my recommended
solution would be the database with all the coupon codes that you have already
mentioned, and don't want to us.
But here's another thing you could try:
In the coupon code each comma separated value probably has a meaning:
As example:d120700000a72cbj001c may be an expiration date. That could
be represented much shorted with a "number of days since 01/01/2000".
1111-1111-11-1 may be the partnumber for a product, which should have
a much shorter record ID in the database. "CD", if you have the partnumber
you may not need the identifier for the category since you get that from
the product record.
So "cd,1111-1111-11-1,d120700000a72cbj001c", could become 1234-1287-EF.
(ES represents a checksum, so customer can not just "build" the code they would like)
cheers,
fober
Documentation
