Abort the default Photoshop progress bar
Engaged ,
Nov 28, 2017 Nov 28, 2017
Hello everyone! Is there any way to abort or hide this "standard progress bar" when exporting high-quality prints through scripts?
I added a custom progress bar to my script that took too long but I sometimes realize that the two palettes are shown at the same time? It would be possible?
That's the palette I'm using! If someone has another functional model I am very grateful
myPrs = new Window('palette', 'Batch Processing');
     myPrs.orientation = 'column';
     myPrs.alignment = 'right';
     myPrs.ProcessHead  = myPrs.add('statictext',[40,0,260,25], "Batch Processing...");
     myPrs.Process = myPrs.add("progressbar",[40,40,260,65]);
     myPrs.Label = myPrs.add('statictext', [150,75,200,120], "0%");
     myPrs.Process.value = 0;
     var LENGTH = 4;
     myPrs.show();
     for(i=0;i<1;i++){
         var PrCounter = 0;
        ProgressBar(++PrCounter, i+1 , 1);
         Function1();
     function ProgressBar(v, x, y){
         var value = (Number(v) / LENGTH) * 100;
         myPrs.Label.text = Math.round(value) + " % ";
         myPrs.ProcessHead.text = "Batch Processing... [" + x + "/"+ y + "]";
         myPrs.Process.value = value;
      function Function1(){
      // my code
Actions and scripting
1.1K
Adobe
Enthusiast ,
I have native progressbar here: Magic scripts for Photoshop (Delete all empty layers faster)
Anyway since version 1.1 it's too fast and I almost never see progress bar but it should be here and should be cancelable.
I don't rememeber excatly but progressbar may return true/false value. And you will store this value in variable. And in "for loop" you are checking if true/false and if so, you will break loop with break keyword.
Problem with native progressbar is that it will not let you do some kind of actions like transform.
Engaged ,
Hi Jarda Bereza what I need in fact is to hide or delete the native progress bar! thus displaying only my custom bar progress palette!
I love these scripts "Magic scripts for PS" mainly the " Advanced Font Remapping v1.0.jsx" Were they all written by you? If the answer is yes, I would like to ask a question:
Have you listed the directory for System fonts? C:\Windows\Fonts
Enthusiast ,
reply to removed(?) comment:
Hmm scripting native progressbar could override progressbar bundled with certain action. I didn't tested it but it would make sense.
Yes these scripts are mine. What is your request?
Engaged ,
Jarda Bereza First of all, I want to congratulate you on your beautiful work, and second on thanking you for sharing it with us. As regards my request:
In my workflow I do not work with system fonts. I usually saved all my installed fonts to all adobe programs at:
C / Program Files / Common Files / Adobe / Fonts /
You could do a little modification on "" Advanced Font Remapping v1.0.jsx "list only the sources of this directory: C / Program Files / Common Files / Adobe / Fonts /
That way, only my work sources will be included in the list.
Could you make this change for me? Thank you
As for progress bar:
I have not been able to do what you suggested because I am still an apprentice for scriptting and my level of knowledge does not allow me to do so. If you have a practical example and can have it, I will be eternally grateful!
Enthusiast ,
Nov 29, 2017 Nov 29, 2017
smithcgl9043167​ How works this folder? Are fonts placed here automaticaly available in Photoshop?
Engaged ,
Hi Jarda Bereza! That's right! If you add any source in the "Program Files / Common Files / Adobe / Fonts /" folder, the font automatically becomes recognized by any Adobe software.
Note!
Before you need to create the "Fonts" folder within the "Program Files / Common Files / Adobe" path then add your preferred fonts.
Enthusiast ,
I will explore if script can see this fonts from script or only system installed fonts.
Engaged ,
I believe you will! Thank you.
