Healing brush edges on gradients display issue
Nov 29, 2017 Nov 29, 2017
I'm using the healing brush to clean up a sky, and I'm seeing subtle edges on the brush locations, but when I merge my retouching layer into the background, the edges disappear, and it looks clean.
Is there some setting I can change to make the layer display properly?
Before merging:
After merging
merged.png !
310
Community Expert , Nov 29, 2017 Nov 29, 2017
Hi
At zoom levels less than 66.7% you are looking at a blend of 8 bit previews. So even a 16 bit image is blended with 8 bit previews at those lower zoom levels. You cannot change that - it is the way Photoshop works and AFAIK was done to speed up full screen redraws.
So the answer is check the asthetics and positioning of image elements at low zoom levels but always check for artefacts at 100%.
Dave
Adobe
Maybe a screen redraw issue - try turning off GPU performance.
Melissa Piccone | Adobe Trainer | Pluralsight Author | Fine Artist
Unfortunately that didn’t work.
Does this happen when you view at 100% zoom ?  Any zoom level less than 66.7% uses 8 bit previews to blend and can show the odd artefact.
Dave
Depends on the image, but it happens at zoom levels of 50% and below. How do I stop this from happening? I often evaluate the look of my retouching by looking at the image as a whole (as I expect many other people do)
Hi
Dave
There are some cases where I would much prefer to sacrifice speed for accuracy, and this is one of them.
There are advantages - although some other may shout foul at any slow down .
There is a feature request linked below but it does not look like it has been updated for a long while. You could add your vote and comments to it to tray and bump it up.
Photoshop: Support more accurate 16 bit/channel display even when zoomed out below 66.67% magnificat...
Dave
