I am running into indexing issues with acrobat 8 and I do not know where to find logs related to the indexing process. I have a large index of PDFs and the index is not working properly. We run index.pdx /build and generally it rebuilds the index properly. This past week it is running through the indexing process (approx 5 hours) and instead of being successful, it just says indexing unsuccessful. Where would I find logs to troubleshoot this further?
Hello mikes16050460
As per the description above, indexing is not working in Acrobat 8, Is that correct?
You may refer and try the steps and suggestions from the following KB docs which discuss similar issue Help with Adobe Acrobat Professional 8 Indexing and Cataloging
Creating PDF indexes, Adobe Acrobat
Note: Acrobat 8 is declared as an End of Life product and End of Support, and the suggested steps/suggestions/workflow may or may not work and the support is limited, for more information refer
...Copy link to clipboard
Hello mikes16050460
Note: Acrobat 8 is declared as an End of Life product and End of Support, and the suggested steps/suggestions/workflow may or may not work and the support is limited, for more information refer to End of support | Reader 9 and Acrobat 9 (and earlier)
Hope this helps and clarifies.
Anand Sri.
