When I go to print the "labels" they are not printing. The box is checked but when I look at what is printed it is not there. Worked perfectly fine in the older version of CC.
Seems to work okay here on win 10 with photoshop cc 2018.
What operating system are you using?
In the photoshop print dialog do you actually see the Label at the top of the preview image?
printed pdf
I am currently having the same problem, windows 10. i select labels, shows up in preview, but not the printed item
Did you try printing to Microsoft Print to Pdf so you don't waste paper while you experiment with different settings like paper size, scaling, etc?
Same issue here. We use this function a lot to create labelled PDFs for proofing. Very frustrating!
i Found it worked fine on another printer
it dosnt work when i printed through accurip, through an Epson 4000. Which is what I need every day.
i ended up reinstalling 2017 version of photoshop.
the lady I spoke to at adobe couldn’t grasp that it was a programming issue, and not another issue
Have you tried removing and reinstalling the printer in your Windows 10 printers and devices?
Having the same issue with Accurip and a 4800. Tried reinstalling the rip and drivers and still the same thing. Getting tired of having to go back and write all the info on the film.
Same here I went back to PS CC 2017 and I've been printing just fine to Accurip. It worked on all other printers that were not using Accurip to communicate with the printer. Thank you to all who have replied so far-glad I am not the only one lol
