Where I come from when people are trying to help us, we don't
patronise them. It tends to backfire.
If you want to continue using your own terms and not explain
things clearly when you can see that both of us trying to help you
are having some difficulty, I'll wish you good luck. We are not the
ones with the problem that needs resolving. Now let's try once
more.
The printed documentation layouts do not generate reports.
They generate some or all of your content according to how you
setup the layout. Reports are generated from the Tools menu. Call
it what you like in your own environment but it is confusing here.
So, if we are talking about topics being printed through a
printed documentation layout, as far as I can tell the issue has to
be the options in the last page of the wizard. If you tell us what
you are selecting there, then perhaps we can help.
I am not following what you mean by "HIghlighted sections of
the output which gave the impression that that output could be in
the form a table in Word". What is giving you that thought?
If you preview a topic from RH and then right click to print
it, do you get the same problem?
