I have attempted to break my equation down and only perform the power or square root functions and the text box does not respond. So i have narrowed it down to the fact that neither of these math functions are working for me.
The custom calculation script for the field could be something like:
// Custom calculation script for text field
(function () {
// Get the field values, as numbers
var v1 = +getField("UserEntry1").value;
var v2 = +getField("UserEntry2").value;
var v3 = +getField("UserEntry3").value;
// Perform the calculation and set this field's value
event.value = 29.84 * v1 * Math.sqrt(v2) * Math.pow(v3, 2);
When troubleshooting JavaScript, it is helpful to check the JavaScript console (Ct
...Copy link to clipboard
I believe my problem statement was cut off. Here is it: I am attempting to develop a pdf form that will perform calculations based on user input. I have been able to accomplish some of the more basic calculations, such as multiplications, but am having trouble when it comes to performing some of the more complex calculations. I am attempting to perform the following calculation (29.84*UserEntry1*sqrt(UserEntry2)*(UserEntry3^2). I have read several forums and I understand that adobe pro uses JavaScript, so I have attempted to incorporate commands such as Math.pow("UserEntry3",2). I have also tried Math.pow(this.getField("UserEntry3").value*1,2). In a similar fashion I have attempted to use the Math.sqrt function with no luck. I do not receive an error with my equation. The box simply is unresponsive to any user input values. Any ideas as to what could be the issue?
(function () {
When troubleshooting JavaScript, it is helpful to check the JavaScript console (Ctrl+J) for errors.
Thank you! That worked great! so if i would want to follow up with the following calculation: AutoCalc1*((UserEntry2 - 20)/(UserEntry2 - UserEntry3))^0.54).
Shouldn't the following script work:
var v1 = +getField("AutoCalc1").value;
event.value = v1 * Math.pow(((v2 - 20)/(v2 - v3)), 0.54);
I am being prompted with a window that says the value entered does not match the format of the field. Don't quite understand the issue.
You need to make sure that the result of v2-v3 is not zero, as that would mean division by zero, which is not allowed.
Change the format of the field to "None" and observe what appears. It could be "NaN", a number expressed in scientific notation, "Infinity", or "-Infinity". You can then adjust your script to handle the result in an appropriate manner.
