Locked
Muse break points
Nov 30, 2017 Nov 30, 2017
Why does my navigation go off the canvas when the screen size changes when I'm using break points? I was told I could pin it to the right but that didn't work.Capture.PNG
453
who told you to pin it to the right? ... anyway the point is you can move the menu "in that smaller breakpoint" so that it is in a different spot than when it is in the bigger breakpoint
or to say it another way, each breakpoint is potentially its own design
My navigation seems to have a mind of its own. As I move the break point in
to the smaller size my nav stays the full size, and doesn't respond to the
break point at all if that makes sense.
it makes sense if you pinned it yes
I removed the pin and it still didn't work. I used Manual in the menu type.
Could that stop it from working, because no matter what break point I used
the menu will not respond to it.
On Thu, Nov 30, 2017 at 10:16 PM, Ussnorway <forums_noreply@adobe.com>
Dec 01, 2017 Dec 01, 2017
If I understand you right, you want the menu to behave responsive?
Then you may see, using the blue arrow - flout options panel, the there´s a possibility to make the menu resize but only if the size is set to "even size" instead of even distance:
If you look at this file, you may see two different menus and how they behave when you move the scrubber.
Adobe Creative Cloud
Wether you use manual type or automatic type, this fits to both menu types.
BTW, the menu settings can be looked at on master-page
Best Regards,
Uwe
My option is uniform size or uniform spacing, and neither work. When I use
the bar to go to a different break point my navigation jumps off the canvas
and stays the same size. I hope this makes sense!
On Fri, Dec 1, 2017 at 8:15 AM, ankushr40215001 <forums_noreply@adobe.com>
a manual menu widget has the same size and location options as the non manual... at this point i think the best way forward is to make a simple two breakpoint example site and share the .muse file so we can have a look at your design.
keep it to just the basics and place it in your cloud (or a dropbox)... to be clear, you want a menu that hugs the right hand side of your page?
p.s, you know that this text is being turned into an image because of the font you used... that is what the icon is telling you
Yes I want it to hug the right side and be responsive. Here is a link to
dropbox.
https://www.dropbox.com/s/gjqcfzucbxkybm5/Website-3.zip?dl=0
Thank you for your help.
Debbie Shotwell
For me it seems to be responsive and resizes quite correct until 768. At that point you should use a so called mobile menu.
This could be either a hamburger menu, triggering a composition or just another menu like you have it already.
You may watch your edited file here:
Dropbox - Website-3.muse​
I changed this double arrow to "look" outside and the menu.
Best Regards,
Uwe
I agree with Uwe the design is the issue and we both change the menu in the smaller breakpoint to allow for more space... so ill add two points;
  1. i think you will need another breakpoint at about 400... unless you are happy to make your name icon smaller
  2. again (the text) is being turned into an image... you have it set to cover the top of your design and that extra bit (in red) will push your design outside the canvas
Dec 02, 2017 Dec 02, 2017
Thank you for your help!
Debbie Shotwell
