【Help Needed】Is there any script for changing font in CC 2017?
Dec 01, 2017 Dec 01, 2017
I tried to adjust the script below in cc 2017. But there are a lot of errors encoutered. The root cause I guess is the the script below was developed in 2010 which was using on a very old version of illustrator. Now, a bunch of the API, function in class don't exist any more.
//get unique Array elements
Array.prototype.unique = function (){
    var r = new Array();
    o:for(var i = 0, n = this.length; i < n; i++){
        for(var x = 0, y = r.length; x < y; x++){
            if(r==this) continue o;}
        r[r.length] = this;}
    return r;
//search inside array
Array.prototype.findIn = function(search){
    var r = Array();
    for (var i=0; i<this.length; i++)
        if (this.indexOf(search) != -1){
            r.push(this.substr(this.indexOf("\t") + 1, this.length));
    return r;
var usedFonts = app.activeDocument.fonts;
var sysFonts = app.fonts.everyItem();
sysFontsList = sysFonts.fontFamily.unique();
sysFontsList.unshift("- Select Font Family -");
var fontsWin = new Window('dialog', 'Document Fonts');
fontsWin.alignChildren = 'center';
var allFonts = fontsWin.add('listbox', undefined, undefined, {numberOfColumns: 5, showHeaders: true, columnTitles: ['Font Name', 'Font Style', 'Font PS Name', 'Font Type', 'Chr count']});
allFonts.minimumSize = [600,150];
var myGrp = fontsWin.add('group');
myGrp.alignChildren = 'center';
var availableFonts = myGrp.add('dropdownlist',undefined,sysFontsList);
var availableStyles = myGrp.add('dropdownlist');
var okButton = myGrp.add('button',undefined,'OK');
var okButton = myGrp.add('button',undefined,'Cancel');
availableStyles.minimumSize = [180,25];
availableFonts.selection = 0;
availableFonts.onChange = function(){
    availableStyles.removeAll();
    var sysFontAvailableStyles = sysFonts.name.findIn(availableFonts.selection);
    for(var i = 0; i < sysFontAvailableStyles.length; i++)availableStyles.add('item',sysFontAvailableStyles);
    availableStyles.selection = 0;
//// SHOW JUST MISSING FONTS //// [START]
for(var i = 0; i < usedFonts.length; i++){
    if(usedFonts.status != FontStatus.INSTALLED){
        allFonts.add('item',usedFonts.fontFamily);
        allFonts.items[allFonts.items.length-1].image = 'SystemWarningIcon';
        allFonts.items[allFonts.items.length-1].subItems[3].text = findCharacters(usedFonts.name);
        allFonts.items[allFonts.items.length-1].subItems[0].text = usedFonts.fontStyleName;
        allFonts.items[allFonts.items.length-1].subItems[1].text = usedFonts.postscriptName;
        allFonts.items[allFonts.items.length-1].subItems[2].text = usedFonts.fontType;
//// SHOW JUST MISSING FONTS //// [END]
allFonts.selection = 0;
fontsWin.center();
var fontAnswer = fontsWin.show();
if(fontAnswer == true && availableFonts.selection != 0){
    var sourceFont = allFonts.selection.text + "\t" + allFonts.selection.subItems[0].text;
    var destFont = availableFonts.selection.text + "\t" + availableStyles.selection.text;
    changeFont(sourceFont,destFont);
}else{
    alert('No Actions taken!');
function findCharacters(findFont){
    app.findGrepPreferences = NothingEnum.nothing;
    app.changeGrepPreferences = NothingEnum.nothing;
    app.findGrepPreferences.findWhat = ".";
    app.findGrepPreferences.appliedFont = findFont;
    var result = Number(app.activeDocument.findGrep().length);
    return result;
function changeFont(sourceFont, destinationFont){
    app.findTextPreferences = NothingEnum.nothing;
    app.changeTextPreferences = NothingEnum.nothing;
    app.findTextPreferences.appliedFont = sourceFont;
    app.changeTextPreferences.appliedFont = destinationFont;
    app.activeDocument.changeText();
Scripting
2.6K
Adobe
Valorous Hero ,
Wow there used to be a document.fonts property? That would sure be useful!
I'm also interested in how this is solved.. I remember something about using metadata these days for getting the document fonts.
Dec 02, 2017 Dec 02, 2017
no there's never been a document.fonts property. Above script is for InDesign.
Heh heh. Indeed it is. This has never ever worked for Illustrator – nor was it designed to.
there you go, thanks jw
Dec 03, 2017 Dec 03, 2017
Thanks man, do you have js/vb script for illustrator
Hi Mike, no sorry I don't
Participant ,
Dec 05, 2017 Dec 05, 2017
So I am not really sure what the purpose of your script is mostly because i dont understand parts of it, nor clear what what problems you are having.
However judging from the title of this thread you want to change the font of text at some point in your script?
Like this?
var active_doc = app.activeDocument;
var text_frames = active_doc.textFrames;
var afont =  textFonts[0]
for (var i = 0 ; i < text_frames.length; i++)  {
     var this_text = text_frames.textRange;
      this_text.characterAttributes.textFont = afont
And you want all the avaiable fonts?
the textFont Object has all the fonts available in Illustrator. I suppose you could loop through or what ever it is you need.
For fonts used in the document I suppose you could loop through all the textRanges and check the characterAttributes to get the font names.
I really dont know if any of this is what you are looking for.
it looks very useful. I will verify. The purpose is that I'd like use javascript to allow massive change font in illustrator cc.
Participant ,
Dec 06, 2017 Dec 06, 2017
So does this code make a costomize popup window populated with all availabe fonts and all fonts in use so you can change all instances of a font in a document???
Thats crazy. I didnt know one could make windows and that sort of thing.
Valorous Hero ,
Yes, with ScriptUI we can make interfaces inside dialogs and palettes, however it's important to also notice the difference in the scriptability of various applications: the Indesign app can be controlled in a far superior way than Illustrator. For example, with .jsx in Indesign you can add menu items onto the Indesign application menu bar, but this feature is not available for us here in Illustrator.
how can I get the fonts used in the document?
Participant ,
Here is a loop that runs through all textFrames and gets the font used.
#target "illustrator"
var usedFonts = []
      var this_text_frame = text_frames;
      usedFonts.push(this_text_frame.textRange.textFont.name)
However this is only good if all text in a single textFrame has the same Font. If you have multiple fonts in the same text frame then you would have to make a loop to look through every character in the document seperately. Below is a quick example.
var usedFonts = []
var listed = false
          for (var t =0 ; t < this_text_frame.characters.length; t++){
               var aFont = this_text_frame.characters.textFont.name
               InArray(aFont)
              if(listed  == false){
                    usedFonts.push(aFont )
           listed = false
function InArray(quiry){
for (var n =0 ; n < usedFonts.length; n++){
    var curFont = usedFonts
        if(curFont  == quiry){
            listed = true
return listed
Thank you Sir! It's really helpful. Last question, how can I replace font for a text frame?
I doesn't work for the following script
this_text.characterAttributes.textFont = "Gotham_bold"
Have a look - the same problem with solution:
Script to select layer by name and change font
Participant ,
Dec 07, 2017 Dec 07, 2017
In my illustrator there is no Gotham Bold, though there may be in your, however what i notice is that the name does not seem to follow the normal naming structure. I believe names are normally capitalized without spaces followed by a dash and the style, also capitalized with out spaces. For example: "ACaslonPro-BoldItalic"
So I would guess that if your font is avaiable on your version of illustrator then it would be "Gotham-Bold".
Correction:
I just remembered this_text.characterAttributes.textFont must be equal to an textFont object.
It is possible however to get a textFont Object by name.
example:
afont = textFonts["ACaslonPro-BoldItalic"]
