Hi there
How are you doing?
I´ve found an excellent script from IndiSnip [InDesign® Snippets] | Adobe® InDesign® Scripting Snippets
It´s a VBScript that I would like to use inside a JavaScript.
When I use it as a VBS file, everything works good, but I am not successful when I write it in JavaScript using the
app.doScript('My VBSCript line', ScriptLanguage.visualBasic);
I did it in many ways, I could not complete the script in debug mode.
Anyone could help me?
Link of script:
Get network adapter Name/MAC/Speed | IndiSnip [InDesign® Snippets]
strComputer =
Set
objWMIService = GetObject(
"winmgmts:\\"
& strComputer &
"\root\cimv2"
Set
IPConfigSet = objWMIService.ExecQuery (
"SELECT * FROM Win32_NetworkAdapterConfiguration WHERE IPEnabled = True"
Set
objWMI = GetObject(
"winmgmts:\\"
& strComputer &
"\root\WMI"
Set
AdaptInfo = objWMI.InstancesOf(
"MSNdis_LinkSpeed WHERE Active = True"
,48)
For
Each
adaptInfo in AdaptInfo
AdaptNameLink = AdaptNameLink & adaptInfo.InstanceName & vbNewLine
AdaptSpeed = AdaptSpeed & adaptInfo.NdisLinkSpeed & vbNewLine
Next
For
Each
IPConfig in IPConfigSet
If
Not
IsNull(IPConfig.Description)
Then
AdaptName = AdaptName + IPConfig.Description & vbNewLine
End
If
If
Not
IsNull(IPConfig.MACAddress)
Then
MACadd = MACadd + IPConfig.MACAddress & vbNewLine
End
If
Next
app.scriptArgs.SetValue
"myAdaptNameLink"
, AdaptNameLink
"myAdaptSpeed"
, AdaptSpeed
"myAdapt"
, AdaptName
"myMAC"
, MACadd
Oh sorry, I forgot to mention: you have to double the backslashes in the vbs string.
This code works:
...main();
function main() {
var vbs = 'strComputer = "."\r';
vbs += 'Set objWMIService = GetObject("winmgmts:\\\\" & strComputer & "\\root\\cimv2")\r';
vbs += 'Set IPConfigSet = objWMIService.ExecQuery ("SELECT * FROM Win32_NetworkAdapterConfiguration WHERE IPEnabled = True")\r';
vbs += 'Set objWMI = GetObject("winmgmts:\\\\" & strComputer & "\\root\\WMI")\r';
vbs += 'Set AdaptInfo = o
Your VB script needs to be a string.
Put your VB script in a variable, and use quotes and line breaks (\n). Then call the script by passing in your variable name (without quotes).
Hi Jake
How are you doing?
About the \n, I've never done it before.
I will try it later and you will send you a feedback
Thanks a lot for the tip.
Jake
How are you doing?
Sorry, but it didn´t work. 😞
Take a look at the above image and you will see the early error on the second line.
Do you have any suggestions?
PS.: I did the same thing with an AppleScript and it worked fine.
Place both scripts in the same folder, like so:
JavaScript
var activeScript = GetActiveScript();
app.doScript(File(activeScript.path+'/GetMyAdapter.vbs'), ScriptLanguage.visualBasic);
var myAdaptName = app.scriptArgs.getValue("myAdaptNameLink");
var myAdaptSpeed = app.scriptArgs.getValue("myAdaptSpeed");
var myAdapt = app.scriptArgs.getValue("myAdapt");
var myMAC = app.scriptArgs.getValue("myMAC");
alert ("myAdaptName: " + myAdaptName + " | myAdaptSpeed: " + myAdaptSpeed + " | myAdapt: " + myAdapt + "| myMAC: " + myMAC);
function GetActiveScript() {
try {
return app.activeScript;
catch(err) {
return new File(err.fileName);
VBS
strComputer = "."
Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2")
Set objWMI = GetObject("winmgmts:\\" & strComputer & "\root\WMI")
Set AdaptInfo = objWMI.InstancesOf("MSNdis_LinkSpeed WHERE Active = True",48)
For Each adaptInfo in AdaptInfo
Next
For Each IPConfig in IPConfigSet
If Not IsNull(IPConfig.Description) Then
End If
If Not IsNull(IPConfig.MACAddress) Then
End If
Next
app.scriptArgs.SetValue "myAdaptNameLink", AdaptNameLink
app.scriptArgs.SetValue "myAdaptSpeed", AdaptSpeed
app.scriptArgs.SetValue "myAdapt", AdaptName
app.scriptArgs.SetValue "myMAC", MACadd
I added the GetActiveScript function so you could run it from ESTK as well.
The result
You can combine both scripts into one jsx-file. In this case VBS should be a string. Use two pairs of quotes -- double and single -- there to include js variables into vbs. I use single outside and double inside.
See here an example of how to do this (Function for Windows).
— Kas
Kas
When I try to execute the VBS as a string in the JS, it not works.
When I do it separated, it works fine.
I would like to convert it in a binary file, and the file as a VBS, I can´t.
The AppleScript made using the same idea works fine on Mac.
This code works:
main();
function main() {
vbs += 'Set AdaptInfo = objWMI.InstancesOf("MSNdis_LinkSpeed WHERE Active = True",48)\r';
vbs += 'For Each adaptInfo in AdaptInfo\r';
vbs += 'AdaptNameLink = AdaptNameLink & adaptInfo.InstanceName & vbNewLine\r';
vbs += 'AdaptSpeed = AdaptSpeed & adaptInfo.NdisLinkSpeed & vbNewLine\r';
vbs += 'Next\r';
vbs += 'For Each IPConfig in IPConfigSet\r';
vbs += 'If Not IsNull(IPConfig.Description) Then\r';
vbs += 'AdaptName = AdaptName + IPConfig.Description & vbNewLine\r';
vbs += 'End If\r';
vbs += 'If Not IsNull(IPConfig.MACAddress) Then\r';
vbs += 'MACadd = MACadd + IPConfig.MACAddress & vbNewLine\r';
vbs += 'End If\r';
vbs += 'Next\r';
vbs += 'app.scriptArgs.SetValue "myAdaptNameLink", AdaptNameLink\r';
vbs += 'app.scriptArgs.SetValue "myAdaptSpeed", AdaptSpeed\r';
vbs += 'app.scriptArgs.SetValue "myAdapt", AdaptName\r';
vbs += 'app.scriptArgs.SetValue "myMAC", MACadd\r';
app.doScript(vbs, ScriptLanguage.VISUAL_BASIC, undefined, UndoModes.FAST_ENTIRE_SCRIPT);
alert("myAdaptName: " + myAdaptName + " | myAdaptSpeed: " + myAdaptSpeed + " | myAdapt: " + myAdapt + "| myMAC: " + myMAC);
— Kas
Kas
You were amazing!!!
The problem was the backslashes.
Thanks, thanks and one thousand more thanks.
Vinicius
I posted it here on my site -- in the tips & tricks section -- for the future generations.
— Kas
Kas
How are you doing?
I am here again because I´m suffering with the same mistakes.
Now I have a new VBS and I´m trying to execute it from a JSX.
The result is an error.
Original VBS
URL="http://viniciusamaral.net"
Set WshShell = WScript.CreateObject("WScript.Shell")
Set http = CreateObject("Microsoft.XmlHttp")
On Error Resume Next
http.open "GET", URL, False
http.send ""
if err.Number = 0 Then
WScript.Echo http.responseText
Else
Wscript.Echo "error " & Err.Number & ": " & Err.Description
End If
set WshShell = Nothing
Set http = Nothing
My version in JSX
#target indesign
main()
function main(){
var vbs = 'URL ="http://viniciusamaral.net"\r';
vbs += 'Set WshShell = WScript.CreateObject("WScript.Shell")\r';
vbs += 'Set http = CreateObject("Microsoft.XmlHttp")\r';
vbs += 'On Error Resume Next\r';
vbs += 'http.open "GET", URL, False\r';
vbs += 'http.send ""\r';
vbs += 'if err.Number = 0 Then\r';
vbs += 'MsgBox(http.responseText)\r';
vbs += 'Else\r';
vbs += 'MsgBox("error " & Err.Number & ": " & Err.Description)\r';
vbs += 'End If\r';
vbs += 'set WshShell = Nothing\r';
vbs += 'Set http = Nothing\r';
try{
}catch(e){
alert(e)
I´ve changed the slash to double slash and it didn´t work.
Can you help me, please?
How are you doing?
I'm fine, thanks. And you?
I know nothing at all about the Windows Script Host thing, but after comparing your script with another working example found here on the forum, the second line stroke my eye.
Try to change
to
vbs += 'Set WshShell = CreateObject("WScript.Shell")\r';
This code works for me:
main()
function main() {
vbs += 'Else\r';
vbs += 'End If\r';
vbs += 'Set http = Nothing';
try {
catch(err) {
alert(err.message + ", line: " + err.line);
I don't have the slightest idea of what the code does, but on my side it results in the following pop-up window:
Hope it helps!
— Kas
Kas
I´m also fine. Thanks for asking.
You are amazing!
I should compare this line with another example, but I´ve focused at the same old error of backslash and reserved characters.
Thank you again.
This VBS reads an web page and return the contents as HTML.
I´m working in a project with online contents.
A´m using an AppleScript too, but it works fine doing the same thing with only 2 or 3 lines.
I have no experience with both languages (AppleScript and VBS), but I should to use it because the Socket of JavaScript is too slow and reliable.
Below you can see one link for a question that I did before about one socket function.
It was solved, but the results take much more time than I have and doesn´t work inside networks handled by proxies.
https://forums.adobe.com/thread/2285205
So, I decided to create a script with 3 different languages inside an only JSX file.
Using ifs and elses, I ready the platform and use the correspondent function.
I don´t know if it is the better way to do it, but it was the way that works fine to me.
You were so important to my ideas become true.
I appreciate, because you spend some time to help me and I know that this issue will help a lot of javascripters.
Vinícius
Hi Vinícius,
This is fantastic! Getting the data using the 'run WshShell via VBS' approach takes nothing in comparison with getting it via the built-in and super-slow Socket object. According to my rough estimates: the latter is, at least, 5 times slower:
Below is the code I used for the test. Both functions perform the same task: read the front page on my site and output the html-contents to console.
Main();
function Main() {
var webAddress = "kasyan.ho.com.ua";
var startTime = new Date();
GetDataFromSocket(webAddress);
var endTime = new Date();
var duration_1 = GetDuration(startTime, endTime);
if (File.fs == "Windows") {
GetDataFromWshShell(webAddress);
var duration_2 = GetDuration(startTime, endTime);
else { // Mac
// The code to be written in AppleScript
alert("Time elapsed:" + "\rSocket - " + duration_1 + "\rWshShell - " + duration_2, "Finished");
function GetDataFromSocket(webAddress) {
var conn = new Socket;
var host = webAddress;
var cmd = "GET /index.html HTTP/1.1\r\nHost:"+host+"\r\n\r\n";
var reply='';
conn.timeout = 100;
if (conn.open (host +':80', 'BINARY')) {
conn.write (cmd);
while (conn.connected && ! conn.eof) {
reply += conn.read(1024) + "\n";
conn.close();
$.writeln("Output from Socket:\n" + reply);
function GetDataFromWshShell(webAddress) {
var vbs = 'Dim str\r';
vbs += 'URL = "http://' + webAddress + '"\r';
vbs += 'str = http.responseText\r';
vbs += 'Else\r';
vbs += 'End If\r';
vbs += 'Set objInDesign = CreateObject("InDesign.Application")\r';
vbs += 'objInDesign.ScriptArgs.SetValue "WshShellResponse", str';
try {
catch(err) {
var str = app.scriptArgs.getValue("WshShellResponse");
app.scriptArgs.clear();
$.writeln("Output from WshShell:\n" + str);
function GetDuration(startTime, endTime) {
var str;
var duration = (endTime - startTime)/1000;
duration = Math.round(duration);
if (duration >= 60) {
var minutes = Math.floor(duration/60);
var seconds = duration - (minutes * 60);
str = minutes + ((minutes != 1) ? " minutes, " : " minute, ") + seconds + ((seconds != 1) ? " seconds" : " second");
if (minutes >= 60) {
var hours = Math.floor(minutes/60);
minutes = minutes - (hours * 60);
str = hours + ((hours != 1) ? " hours, " : " hour, ") + minutes + ((minutes != 1) ? " minutes, " : " minute, ") + seconds + ((seconds != 1) ? " seconds" : " second");
else {
str = duration + ((duration != 1) ? " seconds" : " second");
return str;
Vinícius, could you post the code you use in AppleScript? I'd like to test it on Mac when I get to work on Wednesday.
My fingers are itching to write a post on my site about this new discovery for the future generations!
Also, I found your site. Hope some day you will write about the project you're working on. I wonder what you have at start and what you get after running the script.
Thank you for your detailed explanation! We both learn from each other here on the forum.
Kas
Hi Kasyan
How are you doing?
First of all, sorry for the delay in my answer.
I´m working hard now.
This is the AppleScript code to get a HTML page contents.
var myAppleScript = 'do shell script "curl http://www.viniciusamaral.net/"';
var myCode = app.doScript(myAppleScript, ScriptLanguage.applescriptLanguage);
See, it is so simple!!!
The life in Mac is easier.
Thanks again for your help.
Thanks, Vinícius!
I will test it on my Mac at work later today.
— Kas
Thanks, Uwe!
I will look into this later when I have time: at the moment I am too busy with reworking fonts in FontLab for the current issue of our magazine (to be finished this Friday). Today, all of a sudden, they (our bosses) decided to switch the language: from Russian to Ukrainian. Obviously, they have no idea that a few fonts we use don't have Ukrainian characters.
— Kas
I think we can remove a couple of lines from the VB-script -- by the way, the first one caused the problem in post 9 -- because they are unnecessary:
and
The object is created but never used later in the script. So, why to create it at all?
Here I made a post on my site with updated version. It works without these two lines for me.
— Kas
