After working for some time in Select and mask and making sure that the edges of heair and face were correct I clicked on ok but the iamge I am left with is untidy where it was tidied before clicking ok. Is this normal and can I re-open the select and mask again any way to make further adjustments or do I have to start again or work using brush tools etc to tidy the image?
Any assistance will be greatly appreciated/
David Herd
[Personal Info Removed by moderator]
It depends on what your output settings were when you clicked OK in Select and Mask.
If your output was a Mask or a "New Layer with mask" and you did not check decontaminate colors (which destructively alters pixels) - then just double click the mask* to re-enter the select and mask workspace and modify the mask.
If the output was a selection - then just click on Select and Mask again and modify it.
Alternatively you may need to step back in history and re-mask.
*Note - this needs "Double Click Layer Mask Launches Select and Mask workspace" to be checked in Preferences >Tools
Dave
